Question about Cameras
After I took a picture of fire , something change. Now I cant take a picture at day time -- everything goes white light
    Top Expert:
  • Cameras Master
  • 6,702 Answers
Because you forgot to mention the brand and the model, I can't give specific details, but for al camera's it is almost the same.
There are different scenes you can choose. The wisest thing to do, if you are not sure how to set up the camera is switch it to automatic. This is the green spot, or green camera symbol on the main dial. If the dial has no lock, it is possible you did accidentally turned to another logo. Like yours could be on night shots or fireworks. So just put it on automatic and it will be fine.
Posted on Dec 04, 2014
Hi, I have a problem with my renault megane 1.5dci 2005, it shows check injection light and every time I cold start it fires up after second or third try. I took it to bosch service to get the light reset...
hard starting in cold weather for a diesel is an indication of failed glo-plugs. IF it start ok now then the light was telling you of the glo-plug problem. I would only change injectors as a very last resort as they are very expensive and may not be the fault any way as the easy start indicates no fault there.
Jul 24, 2013 | Cars & Trucks
HONDA CIVIC 2003 GLI Sedan - MALFUNCTION Indicator lamp ON
How is the car running?
Take it for another scanner test ( to a different company)
Mar 13, 2013 | Honda Accord Cars & Trucks
There is something wrong with my flash screen. It's Black. Everytime I try to take pictures on My Finepix z fujifil blue digital camera the screen goes black, and when I go to see what I took a picture...
Flash screen? What? You mean even in pictures with flash disabled (and the flash does drag down the electronics in the thing; make a replacement using an LED lamp and circuit if you have a chance) it takes no picture and leaves you with a black LCD? Are you indeed using a good battery (they go bad gradually (depending on the case on how many times you fire the flash!)) New battery first!
Aug 25, 2011 | Fuji FinePix Z10fd Digital Camera
When pictures are taken outside during the day they are unclear with some white horizontal lines and when taken indoors its ok.tried everything the manual said but still no changes
White shadow or white lines may occur if the light was too bright when you take the picture, especially in strong sun light. Have you turn off the flash light when you taking those picture ? If you haven't, then you should try to turn off your camera flash light manually. And I must remind you not to take a picture with your lens faced the sun light or other light (lamp etc) directly. Even if you take a picture outdoors, try to make your lens shaded by something, you can even use your own shadow to shade them.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 | Cameras
Yahoo Messenger won't display my picture or any other friends picture, and this happens only on my computer
go in the setting and therre will a option of show picture to all my frnds click on this and update ur profile..........then ur picture will shhow
May 20, 2009 | Yahoo Messenger
No picture
hello
Seems to me that your power supply has weak 330 or 470 Mfd 200 volt capacitors.
Use computer grade Caps
I would have them changed first.
Thanks Guy9
May 07, 2008 | LG 42LB1DRA 42 in. LCD Television
Mitsubishi rear projection tv white screen goes dark and....
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change
Mar 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Pictures are all white when using the flash
it seems that the shutter of your camera is having a problem with. normally whin it gets stucked fully open it creats such problem. you need a help of a repairer.
Nov 03, 2006 | Fuji FinePix S5100 Digital Camera
YAKUMO 37 Digital light problems
It's either a white balance issue or an exposure issue
Jun 05, 2017 | YAKUMO Computer Products MegaImage 37...
Blue photos
You probably needed to reset the manual white balance. Lighting conditions can change considerably in 10 minutes at sunrise and sunset.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
