Design of an old washing machine type:1100/16 , gearbox is OK but the rotating part inside the washing area is jammed , how can I disassemble this part to be able to fix it?
I have disassembled the washing pot from gearbox but the shaft of gearbox is attached or jammed to the rotating part inside the washing pot , can you help me? Thanks.
  • Farid Salmanian
    Farid Salmanian Dec 04, 2014
    The name of my washing machine is GALA made in Britain by British Domestic Appliances.
Use a bit of wood and a hammer to persuade it
the bearing your on about perhaps you need to heat up to loosen it off
perhaps its rusted shut so use some penitating oil spray like wd40 or better stuff
i also use the cold approch
here is a product ive used before with good sucess
called 'crack it' its a super cooler spray
http://www.ebay.co.uk/itm/Crack-It-Shock-Freeze-Spray-400ml-VC147-/131354220938?pt=LH_DefaultDomain_3&hash=item1e9552598a
this one on ebay is a 250ml can should be enough to do the job for you spray then wait a few seconds and a sharp tap to the center spindle
Posted on Dec 04, 2014
Testimonial: "Thanks a lot, now it is cold and night I will try tomorrow and say you the result."
Zanussi FJ1214 Washing Machine won't agitate but spins
Sounds like gearbox or check if a belt has came off or slipping underneath.
Nov 01, 2014 | Zanussi Washing Machines
I have a Zanussi Aquacycle 1000. It is taking in water and draining but the drum does not rotate both during wash cycle and spin cycle. Urgent help needed as we have people staying from England and NO wash...
Hi.
If the machine is filling up, then cycling and draining, the problem is usually the belt. The belt is reached disassembling the appliance . If the belt is OK the problem is usually the motor or the motor control unit, which is a sealed electronic module connected to motor and to control board and located inside the washer. If the motor has volts and does not turn, then the motor must be replaced. In some less common case the control module itself may be responsible. Motor assembly and belt are located at the back of the drum and get accessed disassembling top and back of the washing machine.
If the machine does not go through the cycle, but it starts draining from start, then the problem is overfill detected. In that case check the drain system, the drain hose, the inlet valve and the pressure switch.
Regards.
Ginko
Aug 29, 2011 | Zanussi FJS1225W Front Load Washer
How to clear paper jam
How you clean the paper jam depends on where it is located and how large the piece is. If you turn off the printer and turn it back on, then press the "ok" button when it says that there is a paper jam - it will rotate the paper inside forward all the way and then retract backwards. Watch the front of the machine and try to grab the paper when the rollers bring it forward. To get it using this method you have to be really quick. If you dont catch it before it goes backwards then press the ok button and try again.
If you are unable to see the piece of paper when the rollers rotate forward, then unplug the machine from the power source and press and hold the power button for 45 to 60 seconds. Then turn the machine around so the the back is facing you.
There should be an unlockable paper access tray on the back of the printer that has two plastic hinges to depress while pulling outward to remove it. Remove the hatch and see if you can find the paper that is stuck in this area. If so, grab it and remove it.
Jul 17, 2011 | Canon MG5250 Printer
My samsung printer does not feed the paper thru the printer
This is a problem caused by design flaw. There is a sensor inside, which is exposed to high temperature all the time the printer is printing. This part gets broken after a year if you do not print too often and in about a month if you print dozens of pages daily. There is no simple solution to this problem. The part has to be replaced by a trained technician, because it is hidden inside and the technician must disassemble the printer unit to get there. See also http://www.techsupportforum.com/hardware-support/printer-support/350102-paper-jam-samsung-clp-315-a.html
Apr 21, 2010 | Samsung CLP 315 Laser Printer
17 yr old kenmore 70 series HD washing machine will not rotate the agitator, repair or replace?
The transmissions never go out on these. The problem almost always lies elsewhere. If you have someone handy around, it would pay to have them at least look at it and test the wig-wag solenoids. (They switch the gearbox functions/waterpump control.) Cheap fix. Good luck.
Jan 06, 2010 | Kenmore Washing Machines
Agitator sounds as if it's stripped
The agitator and drive gearbox are all one part and are not serviceable (sealed), if it is the gearbox the machine is possibly scrap as the part is more expensive than a new machine. Will need further investigation.
Is the spin OK (quiet) the motor rotates one way to agitate and the other way in fast to spin, the belt may be removed at the middle pulley (Below) rotated in each direction to test. try the machine without the belt and listen to motor.
Nov 25, 2009 | Admiral AW22 Top Load Washer
Dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Whirlpool toploader gearbox/clutch removal
Last Night I took the machine apart to find clutch/brake assy ok gearbox was also ok then I noticed shaft coupling was different than new part I had in stock, new part made totally of nylon, old part fitted to machine has steel insert built into nylon. this was not fully located onto motor shaft and the first 1/4" of motor shaft had been stripped back to round ( no flat faces) also inside the steel lined bore of the nylon coupling had been worn to round.I replaced with new coupling of nylon and ensured both nylon parts fully pushed home onto motor shaft and gearbox shaft with any freeplay / gap being allowed in the rubber drive link. This has worked for now but expect trouble in future with worn motor shaft.
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
The Dryer is not rotating
Asad, if you are hearing the motor trying to start I would start with the motor capacitor. Looks like this model has a wash and spin side. Each side has a capacitor for the motor. The manual is not too informative but it looks like there is a switch that has to be made too. But if you are hearing the motor humm, I would start with that motor capacitor
Jan 13, 2008 | Haier HLT41E Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
