Question about Tools & Hardware - Others
What do TTN 580 15 mm nails look like - Tools & Hardware - Others
There is a nial stuck in my tubeless tyre, it is a headless nail but I cannot grip the nail as it is about 3/4 mm inside the tyre, can I plug it by pushing the nail further inside?
Hi Elferns
Yep! You could do that
But the nail might damage the insides as you hit bumps.
Its a bit long winded but if you prop the car up on a jack and let the tyre down then break the seal from tyre to rim, you can reach inside with pliers and pull it out.
Also Better to use a marker on the outside to mark the entry point. You can buy a small kit with tools & rubber bead to push back in the original hole. The tool pulls out and leaves the rubber bead behind. Cut off excess.
Some people don't... but I prefer to coat the rubber bead with the included rubber glue before pushing into the puncture hole.
Kit available at 4WD shops.
Cheers
Feb 19, 2015 | Cars & Trucks
How do I replace the spring in the latch door on my rn175
There are several methods for installing this little spring. My simple method. You will need 30 mm x 3 mm roll pin and a small piece of nail about 1/2 inch in length. It is very difficult to install the small factory roll pin so I use a longer one then cut off the access with Dremel. Remove the 3mm roll pin and pull out the lever discarding the broken spring. Fit the new spring on the lever using the 1/2 inch piece of nail that can pass thru the 3mm hole of the lever. The piece of nail should not stick out either side so that you can slide in the lever with short pin holding the new spring in place. Now insert the lever in place on the door and hold in position (temp pin aligned with 3mm holes in door ), lightly hammer in the long 3mm roll pin. The long roll pin will push out the temporary piece of nail holding the spring in place. Once the long roll pin is in place, cut off the extra length. Good luck
Sep 11, 2013 | Porter Cable RN175 Roofing Coil Nailer
How to replace a door handle on a 2007 hyundai sonata,
our question is vague. If you must replace the exterior handle only, Point 7 in Prakash's excellent answer is enough.
Tip: to repair a broken exterior handle: fill both sides of the broken handle with metal reinforced epoxy like KwikWeld, then push nails (heads clipped off, 4 or 5 cm long, 1.5 or 2 mm diameter) into the small part (over half the length of the nails will stick out), then put the handle back together and wait. The nails will reinforce the epoxy and you'll have several cm of metal totally filling up the handle where it is broken.
Feb 29, 2012 | 2006 Hyundai Sonata
Cap on gas tank leaks. leaf blower stops after using for 5 minutes and then it doesn't start until it cools off
sounds like the breather on cap is faulty , replace cap
the stopping is most likly a coil going open circuit when hot
and is not producing spark
best way to test is to place a home made tester in line with the h t cap and the spark plug and re run and see if spark fails when hot - then retry cold if spark returned - faulty coil is confirmed
to make a tester
cut a hole of 20 - 30 mm in diameter in a 2 " square piece of wood - drill a hole ( using 3.5 mm drill bit ) in opposite sides all the way through to the centre - then fit a nail that has been sharpened to a point into each hole you drilled
now push the nail points together in the centre of the large hole you cut so that the pointed ends are no closer than 5.00 mm
apart ( you may need to cut the nail heads off )
fit this in between the ht lead and the plug tip
and you might need to tape the unit up so that it stays in place
while you test
try making tester because you can use it on other things as well
cheers
Sep 03, 2010 | Garden
How long is 10 mm
10mm is a Metric measurement. If you go to a stationery shop, look for a school ruler it wld tell you 10mm = 1cm and 25.4mm wld be 1 inch. Or you can use your little finger's nail as approx size.
Apr 01, 2010 | Acme United Corporation 12in Ruler - 12"...
Dewalt nailgun wont punch nails
dewalt nailgun jamming "constantly"
Oct 13, 2009 | Dewalt DC618KA Angled Nailer Kit
Spring has come loose
Springs about 1/2 long by 1/4 diameter....guess it is part of the head assembly.
Jul 23, 2009 | Stanley Staple/Nail Gun Elec
Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
May 20, 2009 | Stanley Bostitch BT200K
Need to know the brand of nails that work with this nailer
brand does'nt matter its the lenght and more inportant is the gauge if its shooting two nails than you are most likely using the wrong gauge example of gauges:16mm 18 mm ect. look on gun it should specify which gauge to use
Apr 30, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
20 people viewed this question
Top Tools & Hardware - Others Experts
ray gallant
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
