Question about Jenn Air Kitchen Ranges
The Jenn Air Gas Range that I have is making a high pitched whistling sound when its turned on. It may do this right when it turned on or sometimes it can take a minute or two. This sound will go on
I called the gas company but they said they were unable to fix. They said that there is too much gas coming in thus the reason for the whistling sound. They gave no solution on how to fix though.
    Master:
  • 560 Answers
There is a gas regulator on the unit. This might be defective.
Call an appliance repair guy to diagnose. Gas is very dangerous and can explode.
Posted on Dec 04, 2014
How do I get rid of high pitched whistle in cabin air system?
blower motor might be going out. worn out bearings.
Jun 28, 2014 | 1998 Toyota Camry
High-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Dec 04, 2009 | Maytag MGC6430 Gas Cooktop
My Jenn-Air SVE47100 slide in electric range does
Obviously it does not work fine. The thermostat sensor or the stat itself could be an issue. Can you see the sensor 'bulb'? Clean it with oven degreaser and steelwool. What is the temp in the oven with a 'oven thermometer'? Is this consistent with the oven readout?
Sep 24, 2009 | Jenn-Air SVE47100 Slide-In Electric...
My car is making a whisling sound when started.
hi ,,two things 1- water pump. but most likely check your pulleys they will make that high pitch noise one of them fixing to go bad and what will happen the belt will jam and jump lose and will lose all power ,,cause you have one belt for alt and the water pump mostly its the pulley right under the alt ,,hope this will help ....Joe
Aug 04, 2009 | 1996 BMW 318
When i give my car gas a whistle comes from the engine. It's a high pitch continual sound. When i let off the gas the whistle stops. It sounds like it's coming from the top of the block.70k miles...
Sounds like a vacume leak, chk. for a cracked or broken vacume line or maybe one came off. Does it idle ruff? With it running open hood and listen for a low pitch whistle you may have to rev it up a little.
May 31, 2009 | 1986 Ford Thunderbird
High pitch whistling noise in engine compartment of 2005 envoy
There may be a small hole or cut in a vacum line or possibly just loose. Also make sure the air filter box and the big hose to it are secure and clamps etc are tight. Pulleys and belts can make a high pitch sound also.
Mar 22, 2009 | GMC Envoy XL Cars & Trucks
High pitched whistle
can u please rate my help? thanks you
Aug 28, 2008 | Daewoo DWC063R Air Conditioner
Problem with Jenn Air Gas Range???
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
Jan 02, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
Kitchen Ranges Logo
97 people viewed this question
Top Jenn Air Kitchen Ranges Experts
 John
John
deton8 von Splosion
Bill Boyd
Are you a Jenn Air Kitchen Range Expert? Answer questions, earn points and help others
