Question about Hobart 4246-1 Mixer-Grinder
I am looking for a wiring diagram for a Hobart 4246 HD Mixer Grinder
I am trying to convert the 3 phase unit into a single phase unit by switching out the motors and the contactors.
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Jul 09, 2014 | Hobart H600 Stand Mixer
I needed to know the PH for a h600 11344142 Hobart mixer... And is it a single Or 3 face??
Hello Jbabajanov,
I understand that you want to know about the HP (Horse Power) of a H600, 60 quart mixer and weither it is a single or three phase.
All H600 Hobart mixers are equiped with a 2 horse power motor.
As to wether it is single or three phase you will need to look at the service tag of the machine. If is listed on it weather it is single or three phase.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Hobart H600 Stand Mixer
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
I have a Hobart 80 qt. stand pizza dough mixer that has lost forward speed, and only works in reverse. Is this electrical controls or a gear problem?
if the mixer is a 3-phase unit, that mixer has no reverse speeds, all gears should turncounter-clockwise when mixer is on ,if a 3-phase unit try switching any 2 of the incomingline to to change direction
Oct 08, 2009 | Hobart D300 Stand Mixer
Wiring diagram for a Hobart D340 40qt mixer
i read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
Oct 08, 2009 | Hobart D340-6009 Mixer
This is a 3 phase mixer. Is it possible to connect it to my single phase bakery without buying a 3 phase converter?
no not without changing mtr. contactors,installing a roto-phaseinverter is the way to go dont get static inverter
Aug 27, 2009 | Hobart D340-6007 Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Looking for a hobart amx dishwasher wiring diagram from 3 phase converting to single phase
sr. we are using Hobart dish /w but not working this properly .when i start d/w display red light coming but not green light also heater working water coming can you help me
Jun 04, 2009 | Hobart Dishwashers
Need to know what type motor is in a hobart D 300 mixer
Look on the I.D. plate. Voltage should be listed. "PH" is for phase. It will either be single (1), or three (3) phase. "AMP" is for ampacity or the amount of power it consumes. Hobart's manual does not list the motor as an entire replacement unit. It only lists parts as if you were to rebuild the motor. Sorry.
Hope this helps some.
Apr 11, 2009 | Hobart D300 Stand Mixer
Hobart 4246-1 Mixer-Grinder Logo
225 people viewed this question
Top Hobart Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Hobart Saw Expert? Answer questions, earn points and help others
