Question about REAR DOOR Toyota Rav 4 1996 96 1997 97 98 99 00 Right
How do I remove relays under bonnet rav4 1996 they have a white base which appears to be restricting relays from coming out
1996 rav4 5 door manual. are the relays secured by some system they have a white base which appears separate from relays many thanks in anticipation of any assistance
  • 36 Answers
The white part is just an intermediate part in the fuse box & is not involved in the removal of fuses or relays.
It's not uncommon for fuses & smaller relays to be pretty tight & require some careful persuasion from pliers (rock from side to side while pulling). Larger relays can be removed in the same way, but without pliers.
Posted on Dec 31, 2014
HOW TO REMOVE PANEL UNDER THE STEERING WHEEL TO GET AT DOOR LOCK RELAYS
I would see if there are two or three screws holding the piece above the dash instrument panel, sometimes this is all one piece
Dec 04, 2014 | 2003 Hyundai Sonata Base
Where is bonnet opener
My answer will be based on an American built, left hand drive vehicle. Just inside the driver door, at bottom of dash should be a black plastic bar, approx 2 inches long with an outline of car with bonnet (hood) raised. Pull on that and the cable will release the bonnet (hood). There is a secondary latch, also known as safety latch, by the latch mechanism under the front of the bonnet itself. It'll be a lever type thing you either push to the side or pull toward you. Hope this information help. This information should also be in your owners manual. But I realize that if you bought this vehicle used, it may well have not come with the manual. Have a good day.
Jul 09, 2014 | 2010 Ford Mondeo 1.6
Code p1282
after looking at the wiring diagram for this issue, I have come to the conclusion that it could be that your fuel pump relay is possibly causing this issue. the relay typically can be found under the engine bonnet near or under a medium black box with either clips or a toggle screw that holds the lid on. remove that relay and try replacing with a new one. or swapping it out with a known good relay,
Dec 10, 2013 | Cars & Trucks
How to change ssangyong head lamp bulb
1. Open the bonnet.
2. go into the wheel well next to the light you want to replace and look forward. you will see 3 screws. 2 of them hold the white plastic fairing at the front in place. Undo those 2 screws.
3. Remove the white fairing at the front (from the wheel well, along under the headlamp) carefully. It is clipped in position.
4. you will see two bolts, one under the fairing you just removed, one on top under the bonnet. Remove them.
5. Pull the light assembly out, there is a threaded cap, behind is the lamp
Mar 31, 2012 | 2007 SsangYong Actyon 4x4
I have a 1992 Toyota Celica convertible. Its an import from Japan (JDM) model. It is the Limited 300. The car is the ST183 version. My problem is the power windows and central locking have failed, i...
I suggest check the next diagrams (click over image for zoom); the legend "a", "b", etc. is the location...
Fig. 2 02 Door lock wiring diagram-1992-93 Celica
Fig. 2 03 Door lock wiring diagram-1992-93 Celica
Fig. 2 04 Door lock wiring diagram-1992-93 Celica
Fig. 1 64 Power window wiring diagram-1992-93 Celica
Hope this helps; keep us updated.
Jul 08, 2011 | 1992 Toyota Celica
Sunroof will not work
Power is supplied to the Power windows and sunroof through the power window circuit breaker. That circuit breaker is supplied power through the RAP (retained accessory power) Relay, the RAP relay also supplies power to the radio. The RAP relay is also fuse protected by the RAP fuse in the under hood fuse block. The RAP relay is energized by the BCM body control module.
The RAP relay is responsible for the radio and windows working after the igntion is turned off.
The first place to check would be the RAP fuse in the under hood fuse block and then the RAP relay in the Body fuse block.
A list of the BODY relay block located on the left side of the dash to the right of the interior fuse block is below:
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay(1) Park Lamp Relay
(7) Door Lock Relay
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay
Jul 10, 2010 | 2000 Chevrolet Blazer
2004 jeep grand cherokee special edition, windows won't work, doors won't lock (except with key) auto door locks doesn't work either, and dimmer switch for dash whenever turned on all interior lights go on...
sounds like a blown relay and also a blown fuse or two, check the relays under the bonnet and under the dash, you will surely find a broken/worn/burnt out one, replace it (not sure which one it is but they renge from £3/$5 to about £12 - $25 then replace the fuses, if there is no bad relay then just replace any blown fuses - hopefully it's just a worn out relay and not something wrong with the windows or locks that blew the relay in the first place -
Jan 15, 2010 | 2004 Jeep Grand Cherokee
Camry 1996 automatic power lock doen't work, but windows work.
if you can here relays when unlocking/locking check for power at door lock actuators inside doors, if you have power on lock/unlock and good earth from connector actuators are faulty.
if no power on test light when operating check output from central door lock module while operating, none coming out of module then it might need replacing.
check 30Amp power fuse for main relay under bonnet (which goes to pin 8 white/blue on module)and 10Amp gauge fuse in cab(pin 1 blue/red on module),pin 15 is also power when relay is on(red/blue) with test light, and module/ actuators.
check outputs from module pin 3 & 4
blue/red
blue/black
that go to door locks
Jul 20, 2009 | 1996 Toyota Camry
When use water dispeser water comes out from behind the refridge
no real "schematic" available showing how hte water lines are run, but illtell you that they start at teh rear of machine,incoming water, form there they travel to the water filter and into an opening under the refrig side. can be viewed by removing hte lower crisper(theres a holding tank) from ht tank goes back out nad heads for the door assy, so a simple trace of water lins will determine point of leak, usually a fiting or hte water lineitself has dry-rotted, in which case needs replacing, hter are no "hidden" lines with refrig, ohter then within the freezer door,and even that can be removed and replaced if ness.
Dec 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Door locks don't work
Disassemble the paneling on left side ,under the steering wheel. Remove all screws and pull out the panel until you can you can reach behind it to remove the two Black Relays, on the side closest to Steering wheel. Remove the Relay covers, Clean the contacts with a 1/8 fine strip of 600 wet/dry sand paper. Only place the paper between the contacts, and pull out while holding slight pressure on the relay Armature. Turn over the sandpaper and repeat once again. Very gently press the TOP resting contact pad closer to the armature, to lessen the gap between the contact points, so the armature doesn't have to travel as far to reach the closed contact position. Repeat the above with the other2nd Relay. Replace the covers, reinstall the relays And test the Door locks prior to buttoning up the paneling. Note, a pair of long needle nosed pliers will help in removing the relays. Just Grip the relay and rock in Forward and Backward as you apply upward pressure.
Oct 08, 2008 | 2001 Hyundai Sonata
REAR DOOR Toyota Rav 4 1996 96 1997 97 98 99 00 Right Logo
63 people viewed this question
Top OEM Vehicle Parts & Accessories Experts
Bill Boyd
Speedracer70
Tom Chichester
Are you an OEM Vehicle Part and Accessory Expert? Answer questions, earn points and help others
