Question about Tablets & eReaders
How to do master reset on the atab ten.1 tablet
I have press the reset button on the tablet and it does nothing my daughter as put pin number init cant remember the numbers
If it has a reset button you need to have the charger connected
press and hold in the button for 30 seconds
then try to power on
Posted on Dec 04, 2014
How do I master reset my EM749 tablet
To reset the tablet (for example if it's frozen and won't power off), there is a small hole on the back marked 'R', near the SD Card slot. Insert a pin or small paperclip into the hole to press the reset button to reboot.
To reset the tablet to factory settings, follow the instructions in the linked PDF:
http://southerntelecom.com/emersonsupport/reset/EM749_Hard_Reset.pdf
Jan 18, 2015 | Tablets & eReaders
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Jul 12, 2014 | Proscan 7-Inch Android Internet Tablet,...
Sent incorrect model no. before. my daughter has set a pin no. password on her tablet in error. She doesn;t know what it is so now we can't access tablet. We have pressed reset button on back but no change...
Isn't this the same problem as this one?
http://www.fixya.com/support/t24390784-pin_no_set_in_error_tablet_now_access
The tablet has no PIN. It is the SIM card for 3G that needs a PIN to access the 3G service.
When you remove the SIM card, the tablet will work perfectly without asking a PIN.
I hope this helps.
May 11, 2014 | PIPO ProntoTec 7 Inch IPS Capacitive Touch...
How to restore this tablet back to factory settings as daughter set pin no. password in error and we can't remember what it is. thanks
start your tablet when network connection is available then it's auto connect and go to the forget password and you can login your registered id then it's open ....
I have locked myself out of my tablet
You will need to do a factory reset:
Oct 29, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Do not have the pin to unlock my toshiba excite 10 tablet what is the code
Factory reset is the only answer;
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
Jan 08, 2018 | Toshiba Tablet. Excite 10.1 in. Android...
Forgot my passcode symbol on my tablet an need to reset it please
This works with devices having physical home button
1.
Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory. With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
Note: I Use My Tablet SUNBERRY, and reset my Tablet
Turn Off your Tablet and then
Press Power + Volume Down (Press up Factory menu Show)
If you use Android 2.2 (Froyo)
Press Wipe data / Factory Reset -> Yes, Delete ALL user data -> if Finish press Reboot Now
If you want more other andoroid OS and other tablet visit my Blog
you can see how to Reset android with video
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 14, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
I have a coby Kyros and I forgot the password and can't get in. how can I take the password off?
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the MID7015******
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
Aug 18, 2011 | Coby Kyros 716829701508 Tablet PC
It was always difficult for me to switch on/off Nokia N800 as its button seemed too soft and fragile. And now I've been using Nokia N800 for 8 months and yesterday its button stopped reacting! It wouldn't...
Do you hear "clicking" when you press the power button? As if it registers the button but does nothing after the "click?" If not, then it sounds like the mechanical/electrical problem with the button. If you do hear clicking maybe if you simply do a battery pull it may reset what was freaking out the power button.
There is a way to reset the UI (rather than cycling the power) but it involves from shell commands:
the XTerm is in the utilities menu. Open that up and type:
/etc/init.d/mce restart
/etc/init.d/osso-systemui restart
Also in XTerm
shutdown -r now
will reset the N800.
Hope this helps,
Bill
Jul 11, 2009 | Nokia N800 Tablet PC
Tablets & eReaders Logo
94 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
