Question about Samsung Cell Phones
How do i fix a problem of inserting a sim card in the phone?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,745 Answers
What problem are you experiencing with inserting SIM?
Posted on Jan 08, 2015
SOURCE: insert correct sim card
i you should try a software update, you can get this from www.sonyericsson.com/support. hope this helps
Posted on Nov 21, 2007
SOURCE: Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Posted on Feb 09, 2008
SOURCE: Insert SIM Card
My phones displays the message Insert SIM Card even though it has the SIM Card.
Posted on May 04, 2008
Put two layers of paper between SIM card and SIM holder to make it a tight hold.It solves your problem.
Posted on Jan 07, 2009
urbanhookupz
  • 213 Answers
SOURCE: WHY DOES MY PHONE SAYS INSERT SIM
try taking SIM and battery out placing it back in an powering on.
If you try this and it still does not work you may need a new SIM card. Take it to a local dealer they should have a new SIM they will put your number on it and you will be back in business.
If the new SIM doesn't not work you will now know it is your Phone, which means time for a new one.
good luck
Posted on Mar 27, 2010
Fix phone says insert sim card
Get the SIM card out and clean it then insert it to the slot again
Jun 28, 2013 | Motorola Cell Phones
How to fix my phone i can't insert other simcard on it?
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Aug 10, 2012 | Samsung GT-E2222 Unlocked Cellphone - US...
Im getting sim card registration failed error in nokia e63
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding Sim card problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone.
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
If the same Sim card doesn't not work on another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jan 24, 2011 | Nokia E63 Cell Phone
My sim was rejected from my nokia N70,now the sim is not usable in any phone!! is there a solution without buying new sim?
Hi, there is a solution.What you need in cases like this Sim issues, are from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vice- versa by inserting another Sim card on your mobile.
If you can't use the Sm card even when it's inserted on another handset,
Hope that helps.
Jan 24, 2011 | Nokia N70 Cellular Phone
Put sim card in and it says insert sim card
Hi,when a phone says insert Sim,it means that the Sim card was not placed properly or the Sim card you are using is damaged ( You can try to confirm the simcard if it works properly by testing it on another phone).
Also thee sim tray that you fix your sim card in the phone might also be damaged.
You can try all,it most be one at of all.
Good luck.
Aug 22, 2010 | Nokia Cell Phones
Inncorrect SIM card.
  • Clean the connectors on the SIM card with a soft brush, cloth or q-tip moistened with any type of unflavoured, colourless alcohol.
  • Check whether the card is damaged or worn in any way.
If your SIM card is damaged or does not work properly after cleaning, please contact your operator to obtain a new SIM card.
Error message Insert Correct SIM
Your phone is probably SIM-locked to a specific operator's SIM card. This is usually the case when you buy the phone from an operator. SIM- locked phones may be unlocked – contact your operator for more information.
Jan 09, 2010 | Sony Ericsson K610i Cellular Phone
I just get a sagem phone from UK but when itook the phone to migeria i inserted the nigeria sim card but unfortunately the phone is still saying i should insert sim when a sim as been inserted already
The phone is probably locked to the UK network you were on, meaning that you can't just insert a SIM card and use it on another network.
To fix this, you'd need to unlock the phone, which might cost you a bit. For more information, see this website.
Jan 01, 2010 | Cell Phones
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Insert sim message
yes there is one way to fix this it would however involve taking it to a repair centre and will probably cost you about £40.00 as it sounds like the charger port has become disconnected and requires a new port and the sim holder has become loosened so therefore needs replacing.
Dec 08, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
