Question about Canon CANNON IR 3530 COPIER FOR 220 VOLTS ONLY
JAM ERROR 0207 ON CANON IR 3530 - Canon CANNON IR 3530 COPIER FOR 220 VOLTS ONLY
    Master:
  • 560 Answers
Open the printer and remove the paper jam.
Posted on Dec 04, 2014
E000732 0001 error in ir 3530 how can i solve
Official instructions from Canon are these, try if it works for you:
Solution 1:
  • Check all the cables outside of the printer: they must be plugged, especially between the differents elements of the copier:
  • Solution 2:
  • Check all the connectors on the main board.
  • Solution 3:
  • Unplugg and replugg all the leads between the boards and modules
Dec 26, 2016 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Code jam 0207 in canon ir 4570
jam 0207: this jam code means paper is jamming in the fixing unit, check that unit for possible obstruction in paper path, or replace fixing film assembly
Apr 28, 2014 | Canon Office Equipment & Supplies
Paper jam at the fixing unit for IR 3530
Check the exit sensor actuatir and the the fusing unit upper and lower roller strippels.
Apr 18, 2013 | Canon IMAGERUNNER 3530 Copier
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Hello Sir, I have Canon IR 3530 Machine, it is not work properly when i am trying to Photocopy of document but when i am taking documents copy than it is not possible for me. My machine becoming very hot...
as I understood, your copier is getting paper jams and heats too much.
The problem can be in the fixing heater. Probably he is heating too much, but in this case you would get error code like E001.
You better call service this problem is hard to resolve by this way...
Aug 23, 2011 | Canon Office Equipment & Supplies
I am using Canon IR 3530 the error code is E000024-0001 please help
I had the same problem on a IR-2230 and I had to replace the Developer Assembly. Check the connection first - have you recently had this worked on?
Mar 07, 2011 | Canon imageRUNNER 2000 Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Message E00024-0001 sur Canon IR 3530
you have paper jam blow out with air in can real good.
Feb 16, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir 2830 error code e 490
SIR CONON IR 2830 COMPUTER SE ATTACH HO SAKATI HE
Sep 03, 2010 | Canon IMAGERUNNER 3530 Copier
Canon CANNON IR 3530 COPIER FOR 220 VOLTS ONLY Logo
128 people viewed this question
old marine
old marine
