Follow this procedure to troubleshoot if the power will not turn on.
Ensure you are using fresh or fully charged batteries. Check if the battery using is NPBG1 (supplied)
IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
Attempt to turn on the camera.
If the issue is not resolved, try replacing or recharging the batteries if available.
Attempt to turn on the camera in Playback/Edit mode by moving the mode switch to the Playback/Edit mode or by pressing the playback button.
Switch the unit to camera mode and attempt to turn on the camera.
If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet.
(Skip this step if the camera being used does not support the use of an A/C adaptor.)
Try power resetting the Camera. (Remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the battery after 1 minute and check if the Camera works normally.)
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
If you're located in the U.S, online repair request can be created for getting the unit serviced at the Factory service center by clicking the link below:
https://eservice.sony.com or else by selecting your country from Sony Global webpage.
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
Turn off the camcorder.
Remove the battery from the camera.
Remove the AC power supply from the camera.
Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject. IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT
YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam 2. Remove the battery or the power supply 3. Turn the switch to CAMERA for about 30 sec 4. Turn the switch to OFF 5. Install the battery or power supply 6. Turn the switch to MEMORY 7. Open the LCD cover and press the RESET button ( small inner button ) 8. You will be prompt to adjust date/time. Do it 9. Take some pictures
