Question about Ariens Garden
Does my ariens 1028 sno-thro model #924116 have easy turn steering
Does my ariens snowblower have easy turn
Fluid levels in gear box
Amber. With machine on level surface,fill gear box with specified gear oil until it starts running out the fill hole on front of gear box.
press the helpful button and follow me on fixya for more tips
Service
Craftsman snowblower auger gearbox lubricant
Sno Thro Engine Oil Gear Case Lube
Auger Gear Oil Sorry to ask again Snowblower Forum Snow Blower Forums
Feb 09, 2016 | Garden
Why sno thro continues to run after ice block is removed
Because that is how it's designed. It's designed to run again, after you remove ice block.
Apr 29, 2014 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Will not go in reverse
yes adjust the linkage so the drive wheel goes past center
of the alum drive disk
Mar 03, 2014 | Ariens Sno-Tek 28 In 2-Stage Gas Snow...
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
I hav a new Ariens Sno-Thro Cab kit, purchased as an open box from my dealer. There are no assembly instructions - I could probably figure it out anyway - and there is a part "B1" which implies...
B2 is the other side's lower handle bar to liken it to a bicycle scenario. You are SOL without it. Contact Ariens or Classic Accessories, the maker. B2's name is "Side Mounting Bar".
Dec 26, 2010 | Sport & Outdoor - Others
How to install spring on Ariens chute
Not a DIY fix as took the snow blower into the shop for them to repair it.
Oct 20, 2009 | Ariens Garden
Garden Logo
163 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
