Question about JVC Televison & Video
I have a jvc db3 hdmi. When I want to turn it on the red pilot light starts to go rapidly on and off for about 15 minutes, during which it is totally non-responsive to anything else I might press on the remote. If I'm lucky, I might be able to turn it on from the ON button on the telly itself, sometimes it just flashes for another 15 minutes. I'm totally at its merci, I can't seem to find a pattern to turn it on, though usually, after having waited for 40 mins for it to finish flashing I can do it.
    Top Expert:
  • JVC Master
  • 37,910 Answers
The power supply is failing.
Posted on Dec 04, 2014
Testimonial: "Thanks, Tom. I'll have that checked. I guess it could anything, the lead, the extension cord, the socket. I'll start checking. That's for the answer."
  • Montse Estrada
    Montse Estrada Dec 05, 2014
    Sorry, Tom, one more question. Did you mean something external like the socket or the extension cord, or internal like a fuse an such?
Giro plus - red light flashes rapidly, tried priming with no success. Anyone have any answers?
Have you tried draining off some back-pressure. That often is what the rapid flash means. Try pushing the hot water button then opening the steam valve. A few seconds after the pump comes on to push water out, the red light should go off. If it takes more than a few seconds, that's probably not the problem. hope this helps.
Sep 27, 2014 | Saeco Odea Giro Plus Coffee Maker
Getting a message that hdmi is blocked?????and have several blinking amber/green light turns red and tv shuts off....help please WD-65737
Hello!
Please, read my previous solution for WD-65.....
you'll find the answer to your questions.
good luck,
thanks,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
The check filter light will not go off even after I have cleaned the filter numerous times; and now occasionally the unit wil rapidly shut it self on and off repeatedly (again the check filter light is...
Apparently, the unit is not recognizing the filter change. So, turn the Master ON/OFF Switch to OFF and unplug the unit. Wait 15 minutes and plug it back in. Turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset themselves and reverted back to the original factory settings and the change filter light is now, OFF.
Hope this helps you.
Jul 08, 2011 | Frigidaire FAH106N1 Wall/Window Air...
I want to light the pilot but do not know how what is the red button for and do you turn on the gas to light pilot?
nope - don't turn on gas at the Range's front control panel to light the pilot lite.
but you do need to turn on the gas to the kitchen range at the plumbers black pipe valve to the Range.
To light the pilot light:
(1) depress the red button (that feeds the gas to the pilot light orifice)
(2) using lighter/match/lit rolled-up newspaper, etc, light the tiny amount of gas coming from orifice
(3) continue to hold dow red button for 1 or 1.5 minutes (this allows heat to bend the bi-metal contact)
(4) after 1-1.5 minutes with a lit pilot light, release the red button - the pilot should remain lit
(5) you're done lighting the pilot lite - turn on the oven (or broiler).
Dec 27, 2010 | Kitchen Ranges
Dryer pilot light goes on then goes right out. dryer wont heat
Hi there. Soon as the pilot switches off (will still be red hot but fade away rapidly) the gas valve should turn on. (make sure gas supply is on) If valve doesn't turn on, check sensor located very near pilot element.
When the sensor "feels" the heat of the pilot, it switches the pilot off and the gas valve on.
Thanks
Paul
Jul 13, 2009 | Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
