HI if you want to unblock your samsung galaxy s2 mobile from network provider lock to freely use it with any GSM sim then code is the best solution to unlock it .You can purchase code from online providers like Unlocking4U.com for reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone then freely use it with any GSM sim ...
SOURCE: Need to reset samsung galaxy s2 phone. Can't
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode"
If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
SOURCE: MY SAMSUNG GALAXY S2 WONT CHARGE
Try connecting your S2 with the usb cable provided to your desktop/laptop. If it starts recharging, then it is definitely your charger thats done for. Get a new charger...
SOURCE: Cannot charge Samsung Galaxy S2
first, test th charger with another phone to confirm if its working or not.
If the rempte is working, then it means the charging port of your phone is defective and needs to be replaced.
Regards.
Testimonial: "Thanks!"
SOURCE: USER MANUAL FOR A SAMSUNG GALAXY S2
http://www.manualusersguide.com/samsung-galaxy-s2-user-guide-manual-pdf-download.html
Hello here is the link where you can download the user manual for your phone. I have downloaded it for you so you dont have to do it but for some reason i cant attached it in here. So instead i give you the link. It is easy jsut go in this site and at the very bottom you will see download samsung user manual pdf. .just click it and you will be downloading the pdf file in no time..
Hope this can help you..have a nice day..
SOURCE: My Samsung galaxy s2 is just dead it doesn't even charge hw do I get it wrk
HI DEAR
IF YOUR S2 IS DEAD THEN IT MAY BE DUE TO 2 CONDITIONS
SOFTWARE: IF YOU WERE TRYING TO FLASH IT WITH CUSTOM ROMS OR IF YOU WERE UPDATING THE FIRMWARE AND THE THE PHONE DRAINED THE BATTERY IN BETWEEN THEN PROBABLY YOUR PHONE BOOT AREA HAS BEEN DAMAGED.IN THIS CASE IT CAN BE REPAIRED BY A PROCESS CALLED RESSURECTION.IT REQUIRES PROFESSIONAL TOOLS LIKE GPG JTAG,RIFF BOX,MEDUSA,ORT JTAG ETC PLUS PROFESIONAL SOLDERING SKILLS.FOR INFO GOOGLE IT WITH ONE OF TOOLS NAME
2)HARDWARE:IN THIS SITUATION YOUR MOBILES PCB HAVE FAULTS LIKE SHORTING,WATER LOGED,DAMAGED CHIPS ETC.IN THIS CASE YOU CAN VISIT HARDWARE REPAIR PERSON/SERVICE CENTER
1 - Switch ON your Samsung Galaxy S2 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S2 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S2.
