Question about Bosch Washing Machines
I can't get the powder/fabric conditioner drawer out of my Classixx 6 so that I can clean it. Does anyone know if and how this can be done?
Usually you pull it out then press down a small plastic latch
some you just pull it to the end tilt it up and it will pull out
like a slide in drawer
Posted on Dec 04, 2014
  • Shelagh Garbutt
    Shelagh Garbutt Dec 04, 2014
    Thanks very much, that worked perfectly.
Excell 7 VarioPerfect: fabric conditioner compartment will not drain
perhaps you need to contact Bosch website for tech support
Sep 21, 2016 | Bosch Washing Machines
The fabric softner is staying in the drawer after cycle has finished. the drawer is clean so dont know what to do to solve this problem. it is modell classixx 6 1200 express
Hi Carol from retired Englishman in SW France,
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 31, 2011 | Bosch Washing Machines
My bosch classixx 1400 express is leaving the fabric conditioner in the dispenser on all cycles.
This is a common problem with many machines.
I suspect that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD then BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
John C
May 07, 2011 | Bosch Classixx WFL 2066 Front Load Washer
My washing machine isnt accepting fabric conditioner
have you lifted up the conditioner flap on the drawer, you would of seen a long plastic tube sticking up, this tube gets blocked from time to time resulting in the softner not going into the machine. if you have cleaned this tube when you took the drawer out, then the only other cause is the solonoid vavle is the fault. this is easily replaced.
if you have any difficulties, you may if you wish, email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My Washing Machine is emptying the Fabric conditioner too early
Washing Machine has started to empty the Fabric Conditioner high water or blokage in draw
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 05, 2009 | Washing Machines
Fabric softener dispenser no longer works on my Bosch, the dispenser remains full of fabric softener, all else ok Bosch classixx 1200 express
Remove soap drawer completely from washer, and thoroughly clean all parts of it, paticularly the conditioner compartment..
Get a piece of stiff wire, and make a right angled bend in the end of it, then poke the wire into all the holes in the top of the soap drawer compartment to clear any possible blockage.
This should solve the prob.
Please rate my solution.
Thankyou.
May 20, 2009 | Bosch Washing Machines
Fabric conditioner not taken or not dispensed.
take out the drawer that the powder and conditioner goes in. the conditioner spout to allow the liquid to empty from the drawer will be blocked with a mixture of powder and conditioner. clear it thru with a sharp screwdriver or similar and wash under the tap. replace back in place should empty fine then. hope this helps.
Apr 12, 2009 | Washing Machines
Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Nov 03, 2008 | Miele W865 Front Load Washer
Bosch conditioner drawer
This problem is caused by the compartment not filling up sufficiently to start the siphon action. First ensure that the drawer is clean, especially the siphon tube then, with the drawer removed, check the top of the compartment. You will find various holes that let in the water, make sure these are clean and not blocked with mould. Clean out with mould remover and wire then run a cycle with no washing or softener/detergent in the machine.
Aug 01, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing machine
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
Dec 18, 2007 | Hoover PE235 Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
