Question about Kenmore Washing Machines
Will not balance a load when in the spin cycle
Not sure what to do
    Problem Solver:
  • 16 Answers
If the problem is vibration when in the spin cycle, you probably have either bad drum bearings (there are two and a seal) or most likely a broken drum spider ( only available for Kenmore as an assembly with drum included ) ,this repair can easily exceed 400 bucks just in parts, it is a very common problem with this machine because the aluminum drum support corrodes and breaks one or more of its 3 arms causing the vibration in high speed operation. Cheers Paul
Posted on Dec 04, 2014
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
Spin cycle causing load off balance
Unless there's damage to the machine it is the load. Make sure you aren't washing to small of a load. People do not realize how fast washers spin to extract. Just like they use tiny weights to balance your car tire, it only takes a little bit of weight to unbalance it.
May 02, 2013 | Fisher and Paykel Aquasmart wl80t65c
Intermittent no spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Washer does not spin out during the spin cycle. Everything else is working properly.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 14, 2011 | Washing Machines
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Spin cycle of my duet washe3r is very loud
are you sure your machine is balanced and installed on a sturdy foundation?
May 27, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Washing Machines Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
