Question about Thule 2002 Nissan Frontier - King cab - Xsporter Truck Rack
How do I fix code P0455 in a 2002 Nissan Frontier
Scanned for code
    Scholar:
  • 132 Answers
Po455 is an evap emmisions leak most likely caused by the purge solonoid or broken hose assuming you have a good gas cap on the vehicle. The causes for your code are as follows missing or loose fuel cap,bad filler neck or evap hose or canister or evap purge or vent solonoid defect.
Posted on Dec 04, 2014
  • jdtech Dec 04, 2014
How do I reset computer on a 2000 Nissan frontier
Why would you keep throwing parts at it and guessing what is wrong? Take it somewhere that has a scanner and see what is setting the check engine light. It could be a speed sensor, or anything for that matter. AutoZone and I am sure there are others will scan the code for free. If you live close to me I would scan it for you.
Oct 21, 2014 | 2000 Nissan Frontier
Check engine light came on, 2003 nissan frontier
I suggest scanned the computer car in order to know what fault code is stored there; note his code number and send us for other details.
Dec 31, 2012 | 2003 Nissan Frontier Crew Cab
Check engine light 2003 frontier nissan
Keep in touch.
Dec 31, 2012 | 2004 Nissan Frontier
My 2003 Nissan Frontier stalled and will not crank up when I. Scanned it the P0325 and P0340 codes appeared. How do I fix this?
I would say that the P0340 is causing your no start problem.....This is a cam sensor code......The cam sensor is in the distributor and is not servicable.....I would recommend taking it to a repair shop to properly diagnose the problem before replacing the distributor.
Mar 17, 2011 | 2003 Nissan Frontier Crew Cab
I recently replaced the passenger side head gasket on my 3.3L 2000 Nissan Frontier. The Check Engine light was on so we scanned it, and it was throwing 3 codes, the first one was a Code 34, the knock...
in your air box you will see a wire with a sensor on top,,replace this sensor and engine check light will be gone the next time you start the jeep ,job done
Jun 19, 2010 | 2000 Nissan Frontier
Speedometer 2000 nissian frontier not working,V6 motor
check your fuses first, if fuses are good then take a look at the speed sensor, the sensor may be bad, also scan the computer for any stored codes,the codes may tell you the speed sensor is bad,
Apr 12, 2010 | 2000 Nissan Frontier
What to do when the engine code comes on with service engine soon on a 2005 nissan frontier 6 cylender truck.
You need to scan the code/codes stored in the computer to see what is malfunctioning.
Jan 05, 2010 | 2005 Nissan Frontier
Nissan 2007 Frontier tire pressure monitoring system
You need to set all the pressures to 35 psi. first then drive for approx.1/4 mile. If this doesn't work to reset the light (keep in mind the code itself will still be stored even though the light goes off) you will need to take it to your Nissan Dealer to have it scanned as there may be a malfunction with the sensor. If faulty and you are under 36k miles then it should be covered under your factory warranty. Hope this helps.
Oct 14, 2008 | 2007 Nissan Frontier SE Crew Cab
I have a 1998 frontier and the service engine soon light came on can I check the codes with the key on off on off then count the flashes or just have to use a obdII scan tool and if so a list of codes...
HI
YOU CAN'T TO DO IT WITHOUT USING THE DIAGNOSES SCAN TOOL ???
WHEN YOU HAVE A CODES NUMBER AFTER CHECK !!!
ASK ME FOR MORE INFORMATION
WITH MY BEST WISHES
Jul 23, 2008 | 2006 Nissan Frontier
Thule 2002 Nissan Frontier - King cab - Xsporter Truck Rack Logo
121 people viewed this question
Top Thule Boating Experts
Tom Chichester
Kar Volk
Richard Warren
Richard Warren
Are you a Thule Boating Expert? Answer questions, earn points and help others
