May tag high efficiency washer runs though cycle to done 5 Mims later starts washingles again
I know what it is rick
carbon dust on the front panel/controller pcb
or as i said the start stop taktile switch is faulty and would need one soldered in
Posted on Dec 04, 2014
How do I put a clean cycle on for a frigidaire affinity high efficiency top load washer?
Hello Tracy, thank you for your post!
From what you have described you need help putting your Frigidaire washer into a clean cycle. In order to further assist you I would need your model number. You can locate your serial tag (which lists your model number) on the door frame of your washer. With that information I would be happy to further assist you. -Matt
Jan 03, 2016 | Frigidaire Washing Machines
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
Maytag high efficiency washer runs though cycle to done then starts wash cycle again
perhaps the taktile switch behind the start stop button has an issue
i recone this is the issue
is the start stop jammed ??? if so press it in and clear around its surface with some spray cleaner and a couple of q tips
Dec 04, 2014 | Washing Machines
Hello I have a washing machine EWX14440W and the green Start Pause LED light is flashing. I have cleaned the fluff filter, turned off the mains and turned it back on again, done a short dry cycle...
http://data.manualslib.com/pdf/5/461/46091-electrolux/ewx_14440_w.pdf?dabc55afaee556910dced33ebba5ef18
This is the manual on your machine. Unfortunately there is no info on the blinking light so I am assuming that it is a delayed start. Now remember this is a high efficiency machine so it may not seem like it is doing anything when it is. As far as the drying part is concerned, check your drying temp. selection.
Dec 10, 2013 | Electrolux Washing Machines
Washer will start and then stop 5 seconds later. It will start again 2min later and stop 5 sec after that?
I have a front loading frigidaire washer which works fine. It starts and stops throughout the whole wash but gets the wash done. That is how it works.
Does your machine simply stop and not finish the wash? Or are you concerned about the length of time it takes to get the wash done?
Aug 12, 2011 | Frigidaire Washing Machines
Stopped on the rinse cycle an give the 5 ud message.
The Sud (5ud) error code indicates a suds lock. This is normally caused by excessive detergent causing too much suds. It can also be caused by not using HE (High Efficiency) detergent. Overloading the washer can also cause this problem. Try running a cycle with no clothes and no detergent added. See if suds emerge in the washer even though no detergent was added.
Nov 21, 2010 | Washing Machines
I don't really have a problem, except that my water bill is eating me alive. Approximately how much water does a full load in my 26912 with one rinse use? And how much water are newer models using on...
Most standard top loading washers have a 35 gallon tub capacity. If you go with a High Efficiency (HE) model washer, which can include the Oasis and Cabrio TOP LOADERS, and the Duet, Elite and Epic FRONT LOADERS, they use about 5 to 7 gallons. High Efficiency washers also do not have a continuous motor in action during agitation or tumble cycles, while most standard top loader have a drive motor that runs throughout the cycle. this can also cut down on the amount of electricity that is used. I hope this helps you.
Feb 17, 2010 | Washing Machines
The laundry is still wet after a normal wash cycle, because the machine doesn't get into the "high speed spin" (this has happened several times . . . have only had it 2 weeks). It has happened on full...
Since it can spin by selector then there is no problem with the spinning mechanism. Need to call warranty service to address the electronic sensor control.
Jan 09, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
