My freeview recorder only finds 3 tv channels
It started by not providing the guide so I could not record anything. I did a factory reset and rescanned, I have rescanned umpteen times but it can only find 3 channels, non of which I would watch. I have tried in different locations but no results. Is it time to throw it away.
Sounds like an internal psu fault
take it to the local TV shop and ask them to analyze its fault
usually a couple of bad capacitors
Posted on Dec 04, 2014
Testimonial: "Thanks I will try that"
How to retune freeview tv
You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 07, 2014 | Sony BRAVIA Televison & Video
My thomson freeview recorder has stopped giving me the option to record the series
Try going into main menu and settings then try to find factory reset .reset all . You may ahave to reload channels afterwards to do this go back to settings then installation then find the button to replace channels .let me know if you are successful . My email is michaeljamescolegate@gmail.com . Yours faithfully Mike Colegate
May 18, 2014 | Televison & Video
I have just bought a Digihome pvr320sd tv recorder with freeview, can i set it up as a tv recorder only without the freeview as i already have built in freeview on my tv.
When you set up the recorder Freeview stations will be stored. This means that you can record TV stations without watching them. So you can say watch BBC1 on your TV and record a program on Channel Four. You need the recorder set up with Freeview to recorder channels. Otherwise you would have to have your TV on and recorder set to record via the scart lead. Which would be not great quality and messy.
You should be able to loop the aerial lead so that both the TV and recorder can get the signals from your aerial, if that's what is bothering you.
Dec 22, 2012 | Televison & Video
Can not find my instructions book to turn my freeview tv into my video recorder
If the TV has a scart then you don't need to tune it. All you need do is connect a scart to the VCR and TV. Then when you want to record anything, set the VCR to an AV setting instead of channel 1 etc. You need to set it to the one with the scart, as the VCR will have more than one AV looking at it's picture. You then just press record. You won't be able to change channel, or the VCR will record that channel instead.
If this is a problem, get a freeview box and just have it connected direct to the VCR.
If the TV has only one scart, you can get one of these boxes below.
Feb 09, 2010 | Sharp VC-H812U VCR
LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
May 12, 2009 | LG RH266 Recorder
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
Problems using video to record from tv
The tv has 3 scarts try connecting to AV3.
If still no luck go to the TV Menu and then 'Setup Menu' find settings and change AV2 OUTPUT TO TV.
Nov 11, 2007 | Panasonic TH37PX60 37 in. Plasma...
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
