Question about Fishman SA220 Solo Performance System Speaker PA Active
How do I add a footswitch to Fishman SA220 to turn off effects to speak to audience
Can manually turn off effects but not very helpful with guitar in hand.
2 Suggested Answers
rb77x7
  • 62 Answers
SOURCE: How can I get a manual for the Fishman sa220?
It is available here:
http://www.fishman.com/files/sa220_user_guide.pdf
Good luck, and I hope this helps!
Posted on Jul 01, 2011
Testimonial: "The answer was 100% successful. Thank You"
How do I get a schematic diagram for Fishman SA220?
Fishman generally doesn't supply schematics to end users. Your best bet would be to find the authorized repair center nearest to you and jus t let them deal with it.
Feb 27, 2017 | Fishman SA220 Solo Performance System...
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
It is not a problem yet, but how do I connect a Fishman Triple Play to my acoustic guitar
with most add-on products like this, they would be self adhering. I suppose if you want it there permanent, a bit of glue.
Jun 26, 2012 | Music
Where is the fuse located in the fishman solo amp
The fuse is inside and if it blows, there is something wrong that caused the failure and MUST be repaired as just changing the fuse MAY do additional damage.
Jul 05, 2011 | Fishman SA220 Solo Performance System...
When I connect the onboard Aura via USB to my computer and open the Aura imaging software, it doesn't recognize my device and a fishman product..... HELP!
You could call Martin Guitars at 1-888-433-9177, or visit their website:
http://www.martinguitar.com/contact
And/or try Fishman:
http://www.fishman.com/contact
Although they don't have a recognizable toll free number, they do have an online form.
If you have access to support for your computer, you could try that, instead.
Jun 29, 2011 | Martin Guitars Martin 000C-16RGTE Aura...
The control for the Effects Loop Mix seems to function like a master volume control. I get no sound in ay channel if the Effects Loop Mix control is in the "EFF" position (right) and sound...
That is the way it is supposed to work... It is a level control to control the level sent to an EXTERNAL effects unit. What external effects unit are you using? Brand and model please. If you proportion more to the effects loop, you want to make sure the EXTERNAL effects unit is on and its gain controls are up. The foot switch input should control the EXTERNAL effects unit when you plug the footswitch into the EXTERNAL unit. The footswitch input on the amp itself has NOTHING to do with the external effect loop, it only affects the amp's own DFX unit.
Jun 25, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
When i press the harmony effect i have to hold it
Well i hope the latching mechanism isn't busted!
Check/review your parameter settings for your programs. Especially in the Expression Pedal Control areas.
From their site:
--Harmony Footswitch
This footswitch turns the harmonies on or off. While multiple harmonies can be selected within a preset, the HARMONY footswitch activates or deactivates any selected harmonies simultaneously.
When the LED above the HARMONY footswitch is illuminated, the harmonies are on. When the LED is turned off, the harmonies are turned off.
--Note: The settings for FX Footswitch Control, Harmony Footswitch Control and Guitar Sensitivity apply to ALL presets. The setting for the Expression Pedal Control applies to the current preset only. If you modify the Expression Pedal setting and wish to store it you must Store the preset (see page 11 ). When you load another preset, its setting for Expression Pedal Control will take effect.
--To perform a Factory Reset procedure
If you are editing a preset, press the Up or Down footswitch to exit edit mode.
Press and hold the Major/Minor button and then press and release the Store button. The display will read FAC RESET- WILL ERASE ALL YOUR PRESETS... , then STORE=RST.
Press the Store button again to continue with the factory reset. If you don’t want to do the factory reset, just wait 5 seconds, or press almost any other button, to cancel.
Mar 27, 2010 | Digi-Tech Digitech Vocalist Live 4...
I need the operation manual for a Danville tec80G guitar amplifier. I also need to find out where I can get a footswitch for this amp. I would like to be able to incorporate some sort of distortion...
Well,its a real obscure amp.No company website from what I can find.
Here is a review of the amp though on a good tab forum:
http://www.ultimate-guitar.com/reviews/guitar_amplifiers/danville/tec80g/index.html
As for the footswitch dist.pedal,you have a few options.Look on the back of the amp and see if there is A)an effects loop.This may say "return" and "send" and you can hookup a pedal through that to bypass the input jack.Then just plug in normally to the front of the amp.Also check to see if there is a 1/4 input on the back that may say "footswitch".If so,fender makes a button footswitch that comes with most of their middle of the road combo's.This plugs in just like a guitar cable and will switch your channels.
If you need a recomendation on a distortion pedal go with MXR.Its a little morre expensive(by $10.00 maybe),but its the best bang your gonna get out of a pedal.
Sep 21, 2009 | Music
Fishman SA220 Solo Performance System Speaker PA Active Logo
49 people viewed this question
Top Fishman Music Experts
Matthew Spark
Matthew Spark
rhodesworks
Are you a Fishman Music Expert? Answer questions, earn points and help others
