Hello, I have m audio fast track ultra. Every time i am trying to listen to music or recored i hear static noises and sounds of blasts. If i disconnect it and reconnect it helps. I have the newest driver. What maybe the problem?
  • Gale ep Dec 09, 2014
    What is S.O?
  • Maxx Dec 09, 2014
    Sorry, I mean operating system version. BTW, if cables are OK, maybe a problem of settings, like latence. Are you able to look in control panel/M-Audio how is the latence setting (128, 256, 512, etc...)?
  • 23 Answers
what S.O. please?
Posted on Dec 09, 2014
Testimonial: "What is S.O?"
    The os is Windows 7.
    I have tried changing the latency but it didn't help. The cable is fine. I tested it with 2 different cables
SOURCE: Sound but no voice, internet radio
ưqettrfg
Posted on Nov 06, 2008
  • 26 Answers
SOURCE: M-Audio Fast Track Pro
I guess if your still looking for an answer your probably desperate. Never the less, if someone else is looking for an answer you need to select FT Pro in the preferances. Basically, you have to tell the software what to record and when. Pretty easy really.
Posted on Apr 14, 2009
SelfHelpComp
  • 146 Answers
SOURCE: some times i have sound ,also it will all of a
sounds like the cable may have a cracked wire, or the place you plug into may have a fractured connector. What computer are you using?
Posted on Nov 27, 2009
  • 733 Answers
SOURCE: dell precision m4300 frustrating audio problem
try to instal with this program your drivers from here http://www.radarsync.com/ if does it not work maybe is hardware problem that must be check in service.
Posted on Dec 07, 2009
SOURCE: Gaps and noises in my Session recording
Is it bus powered? If it is only plugged into the USB port and not also into the AC outlet, it may be because your USB port does not supply enough voltage or enough current. USB is spec'd at 5V, 500mA, but many fall short. I have the same problem with a Tascam US-122. I haven't tested yet, because it doesnt have an external power port. I would need to splice 5V power into the USB cable.
Posted on Jun 10, 2010
Which headphone I should buy Please suggest me a good one.
Would like to know what your max price will be as £600-1000 has some good headphones
Jul 03, 2017 | Audio Players & Recorders
Why do i hear some sort of static whenever a sound comes through my fast track, but doesnt happen when im just listening to sound straight out of the computer?
Open up your computer to check usb connection make sure the connection is good and dust free
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Mar 06, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
I have a phsssst noise in the rear left channel of my Marantz SR5200 AV Amp which occurs when I turn amp on. You can also hear it on some music. It sounds like a connection problem but have checked cables.
Check the routing of the cables to make sure they avoid power sources and magnetic fields.
I have a buzzing sound when I use my track lights which have a fader, so I avoid using them while listening.
Feb 27, 2011 | Audio Players & Recorders
User hears faint static while on a call. It's not load enough to make it hard to hear the caller, but a noticable crackling/static noise can be heard in the background. happens on every call.
Cell phones transmit the sound as digital data. The data when converted back to analog to listen too CAN have "digitizing noise" which will sound like static.
WORSENING the problem is if there is noise in the background of the person sending the voice and the worst possiblle is to have MUSIC in the background. These both drive the CODEC (the analog conversion system) crazy and will create what you describe. The CODEC is designed to transmit ONLY voice.
Oct 23, 2009 | Motorola Mobility Moto Q
Volume on laptop wont work.
Firstly, try removing/uninstalling your audio drivers, then reinstalling those.
Jun 06, 2009 | Acer Aspire 3690-2196 Notebook
No sign of life in external notebook speakers
  1. If the powerlight is turning on some times and off sometimes, Then it may be a problem with the powersupply connected to the speakers. Check it.
  2. If the speakers are on and are not playing, Then try playing some music through alternate source like ipod,walkman etc.If the speakers are playing with alternate music source, The try reinstalling the audio drivers of your note book.
  3. If not then your speakers might have fried up due to some reason.
Feb 01, 2009 | Audio Players & Recorders
Sound card freezes up
Buy enternal power supply for it.
9 Volts
1000mA
But mind that it should be psu with REGULATED output(steady 9Volts).
Apr 25, 2008 | M-Audio Fast Track Pro External Sound...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
