Question about Ovens
How i can change the lamp in my Bosch oven? - Ovens
First .... and important you need to use an actual over bulb or it will explode you can get them at even the £1 shop
its a special type of glass
anyway locate the panel for the bulb and examine it
you may find it has a couple of screws to remove the glass panel and unscrew the bulb you may need to drop the rear panel off to access it all ovens are different
dont worry an oven bulb is a standard type just about for all the ovens ive seen
Posted on Dec 04, 2014
    Master:
  • 560 Answers
Remove the glass cover and unscrew the bulb.
Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
How to change light in oven westinghouse florentine
Turn off the power to the oven. Grip the glass light cover and turn anti-clockwise. I think the lamp then unscrews.
Replace lamp, turn on power and check if lamp lights up, replace cover twist clockwise to fasten.
Jun 29, 2014 | Ovens
How do I change Bosch oven clock from military time?
We have an older Bosch Oven (maybe circa 2010), and the way to access the special settings is to hold down the "Temp" button for 2 seconds which reveals a hidden menu of goodies. I made two changes in there--changed it back to 12 hour instead of military time as well as disabled the annoying beeps every time you press a button. Manual is here: https://media3.bsh-group.com/Documents/9000369981_A.pdf
May 17, 2014 | Bosch Ovens
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
We are trying to replace the lamp in our Bosch Double oven but are unable to unscrew the lamp cover. The oven is very new but the Manufactors service agents dont want to know. Any guidance would be very...
Hello Graham,
The lenses unscrew anti-clockwise, but they can be very stiff and difficult to grip. The best advice I can give you is to double or triple wrap a thick elastic-band around the lens as this will give you much better grip than you will get on the glass alone.
If you are still unable to unscrew the lens, squirt a small amount of WD40 / penetrating fluid down the back of the lens so it runs onto the threads and leave it for 15-20 minutes then try again with the elastic-band grip. Once the lens moves a small amount it will unscrew relatively easily. The constant heating and cooling of the oven causes them to lock.
Please switch off the power supply to the oven before replacing the bulb and make sure you have clean hands when replacing the bulb - grease from your fingers can cause the bulb to fail or shorten its life considerably.
Hope this helps. If you are still unable to unscrew the lens, please let me know.
Regards,
BElectric.
Apr 12, 2011 | Bosch HBL 5056 Electric Double Oven
I have a bosch double oven and the main oven fan element has failed. Do I have to remove th eoven to get access to replace it
It should not be neccessary to remove from cabinet.
Remove cover at rear of oven and you should be able to change the elemnt from inside.
Feb 10, 2011 | Bosch HBN 43R550B Electric Single Oven
Oven door not staying fully open
phone bosch for clarification first. If this is not the case get the gas board out again
Oct 21, 2009 | Ovens
I have a Bosch double oven and the light is out and how do I get the cover off to replace the bulb?
To change the light you need to unsreew lt lens then pul the bulb straight out to you. then reverse the steps to put back together.
Dec 17, 2008 | Bosch HBL 5056 Electric Double Oven
Fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
Ovens Logo
94 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
