Question about Water Water Heaters
Is the junkers WR 11 Gas water heater ok for outside mounting
    Scholar:
  • 94 Answers
No all water heaters need to be mounted inside. Helps with the equipment efficiency, corrosion due to exposure to the elements, possibility of incoming water freezing. It\'s bad on electrical connections, the UV lite is hard on any plastic parts. These things are meant to be installed indoors.
Posted on Dec 10, 2014
I need parts for a Junker gas water heater in Spain. I can't find a parts outlet anywhere on line.
then go to a local plumbing supply house in Spain .not everyone uses the internet to do business
Aug 18, 2015 | Water Water Heaters
Junkers wr11 has no spark and no power
Is it gas or electric? if it is gas and has a pilot, and the pilot is out. If you don't smell gas go through the start pilot proceedure. when the pilot is running it produces a small electric current sufficient to hold the main gas valve open; then the temperture sensor allows the unit to keep the water heated.
Oct 29, 2014 | Water Heaters
Junkers WR11 Water Heater Keeps Switching Off
Do NOT disconnect anything. Has the unit been maintained, cleaned and serviced? There may be a limit switch malfunctioning. Your safest bet is to have it checked out my someone who knows and is familiar with the unit you have, could be simple, but be safe and have it looked at.
May 27, 2014 | Water Heaters
Flame burning too orange
You must get more air to water heater, and check venting .... immediate CO poison danger.
Call qualified plumber immediately.... because deadly carbon monoxide is not being vented properly.
http://waterheatertimer.org/Water-heater-safety-precautions.html#soot
Gene h
Mar 27, 2014 | Water Heaters
R85 tankless water heater
Probably frozen. Let it thaw out and see if it works. You may want to think about wrapping the pipes with heat tape because of those low tempertures they could break especially if the unit is outside.
Good luck,
Marty
Jan 07, 2014 | Rinnai Digital Remote Water Heater Control...
Junkers gas geysers not heating water much
between 60 and 75 degrees c as any hotter will scald you. Have the gas specialist check it out as it may not be getting enough gas flow to the burner either a badly adjusted regulator or a blockage in the gas tap or line.. You control the temp by the amount of water coming out of the tap as you found out when you attempted to restrict the water flow.
May 29, 2013 | Water Heaters
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
May 31, 2017 | Water Heaters
Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Mar 02, 2010 | Water Heaters
Water Heaters Logo
96 people viewed this question
Top Water Heaters Experts
D. E. Hev
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
