My intelowasher keeps water running? WD-80613 front loader runs for 5 mins then error code FE? comes up and water keeps running thru it even when i unlug the power from the wall? i have to turn tap off any ideas?
Yes the intake valve has failed
or the machine is fitted with a low pressure valve and your using high pressure water supply
i recon the valve spring or something has failed
youll need to replace the cold water intake valve {ebay or local shop}
then clear the error by resetting the machine
mains off press button on the front main on wait 5 secs
usually they beeeep one long beep and your done
Posted on Dec 04, 2014
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Nov 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Good morning, we have a LG Tromm front loader that started giving us some problems last night. It seems as it will not shut off, the water is continually filling in the machine, and it keeps draining. ...
"FE" means (no surprise here) "Overflow error. The water is automatically pumped out because there has been an overflow.
Since this condition clearly demonstrates that the water level sensor is working fine and doing its job, the very likely culprit is the water inlet valve. You may be locky and find that of you take the valve out, there is an ovstruction in it (sometimes a bit of grit gets trapped in the valve holding it open. More likely, the valve is failing and not shutting once it has opened. You may then need to replace it.
Jul 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
We have a LG frount loader and just moved house and now it seems to me stuck middle cycle the message comes up isOE I have checked it is level water is on and the machine runs for 5 mins or so then stops...
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jan 15, 2011 | LG WM1814CW Front Load Washer
Top loader door wont open
Something has caused the washer to not release the door. Is there an error code that is flashing (FE?). A locked door can be due to too much water in the basket, suds causing false water detection (should be using HE), or perhaps the drain is clogged.
If you are sure that the water is not going to spill out on floor, then you might be able to get door open by unplugging the unit and waiting a few minutes (mine took an hour) for the electric lock to release.
Sep 15, 2009 | LG WD-16115FD Front Load Washer
Samsung WD-J1255 Front loader Washer/dryer combo
I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
Nov 01, 2008 | Washing Machines
Fe MEANING
It typically means that one of the water valves (that opens and closes to let the appropriate amount of water into the machine) is not functioning properly. It is frequently accompanied by a continuous flow of water into the machine (although with the drain pump also running you won't necessarily see any water building up inside the drum.) I believe the letters actually stand for "Fill Error."
Mar 17, 2008 | LG WD-3274RHD Front Load Washer / Dryer
FE code water overfills due to faulty water valve
Water valve is stuck open and needs to be replaced.  The best way to check if the water valve is the problem is to remove the top cover, run the machine to get the water running.  While the water is filling, remove the connector to the water valve that is filling.  If the water continues to run without the connector, the valve needs to be replaced.  If the water stops flowing when disconnected, you may have a control board problem and will need it to be replaced.
Jan 08, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
