Question about Home Security
My home security light is flashing how do i turn it off
The house was beeing pressure washed at the time i was out the alarm went off i was told it was for afew minutes i noticed mt ventis system wasn't on checking the meter board the switch that contols the light was off put it back on the ventis and lights came back and now the security light is flashing how do i stop it
You need to enter the code and press reset
then the alarm condiction is reset
Posted on Dec 04, 2014
Security alarm problem
Replace the alarm system cos your Harley has probably shook it to death!! Genuinely!!
Mar 13, 2014 | Harley Davidson Motorcycles
Tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
on Nov 08, 2010 | Toyota Pickup Cars & Trucks
My remote was working fine and then after I went to the car wash I went home and tried to turn my alarm on it doesnt turn on
hi
i would check or change my remote batteries first or take it back to the installer to check
its a common problem with car alarm systems
aries
Oct 10, 2013 | 7701V Responder SST Remote
My gardtec ace home alarm external bell box wont
I'm not familiar with your particular alarm bell but most of the ones I've worked on have a dot on the gong that should be aligned with where the strike hits the gong. This is the "sweet spot" where the bell sounds the loudest. Another possibility is the gong may have loosened up and needs to be tightened or there is debris in there that needs to be cleaned out. I have found that bees and hornets love to build their homes inside of these boxes.
Mar 02, 2010 | Kjb Security Sn1 Telespy, Portable...
Security light flash no security system on truck
sometimes turning the ignition on 3 times quickly without starting will reset the computer. If the van has power locks and keyless entry then try using only the keyless entry. Sometimes your car wont have a alarm but an anti theft device which will not allow it to start if it goes off or something triggers it.
Jul 26, 2009 | 2003 Dodge Ram Maxi
Alarm
Mine has done this and i as well do not have a working remote. To disengage it just put the key in the driver door lock and turn for 2-3 seconds and it will disengage. i didn't even know mine had an alarm until coming out of work one night and it went off and i could not get it to turn off unless i went to "unlock" the door and hold it there for a few seconds.
Apr 14, 2009 | 1999 Dodge Durango
Alarm wont shut off and lights keep flashing
This can be very simple look for alarm brain and unplug the brain, this vehicle should start. if it doesn't the look for valet switch it usually mounted under dash or on kick panel next to hood lever or close to where clutch pedal will be, Turn Ignition ON and in ON position flip switch the led light should stay on steady then the vehicle will start. If None of this works then you will have to take panel under steering column down and disconnect complete alarm system. Disconnect wires one ar a time and re-join them with the correct ones. It's NOT hard to do, there will be spliced into ignition wires.To do this you should disconnect positive lead on battery pole to stop the annoying noise until you are done. Good luck and contact if you need more help. Thanks for using FIX YA
Mar 24, 2009 | Vehicle Parts & Accessories
Home Security Logo
1,335 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
