Question about Sharp Office Equipment & Supplies
How do I check the meter reading on a sharp MX-M565 copier
    Habit-Forming:
    Scholar:
  • 47 Answers
If you double click the HOME key it should display all the meter readings.
Posted on Jan 02, 2015
SOURCE: Help
Sorry bubbabear 64, you are wrong you need to reset the copier with sim 14, once you have cleared the jam, there is no sensor in the fuser so often if the paper gets crumpled in there is doesnt trigger and sensors so the customer trys to copy again and again, seen it many times.
John Sharp Tech
Posted on Jul 22, 2008
Bubbabear64
  • 2794 Answers
SOURCE: setting the new meter reading
I found it.
To get into service mode press the clear key. Press interrupt.  Press 0.  Press interrupt.
All counter reset codes start with the number 24.  So put that in first and press the start button.
Then type in a 1 press start.
Then type in a 2 press start.
Do this for numbers 3-11 and 13.
That will reset all of the counters on the copier.
Turn off the power once you're done.
Posted on Sep 18, 2008
  • 117 Answers
SOURCE: add user codes to a sharp mx-4501n mpf
Try exploring the device's web management interface.
Use your wenb browser to connect to the device's IP address.
the default credentials for the unit are user: admin pasword: admin
if that does not work, try password: Sharp (note that the S is capital and the rest are lower case)
Posted on May 07, 2009
  • 120 Answers
SOURCE: hello i have copier machine sharp mx-450u,with
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Posted on Jul 09, 2009
  • 118 Answers
SOURCE: How do I get to the black toner reading on a Sharp AR-M257 copier
Hold down the Copy button and you should see a readout for the total copies printed from the copier and the percentage of toner left in the unit.
Posted on Aug 28, 2009
Err failed to expand ARM9 prg for mx-354N copier sharp mx-354N copier sharp mx-354N copier
Have you tried resetting the copier by unplugging it and waiting a few moments? If you problems persist check us out online for all your Copier Repair needs.
Apr 06, 2016 | Sharp Office Equipment & Supplies
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
PCU PWB EEPROM CHECK SUM ERROR
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
6.November.2015
Feb 27, 2015 | Sharp Office Equipment & Supplies
Disable count meter
be more specific...
if it is an office copier and you are not the person in charge/in direct communication with the copier maintenance company... stop making non-work related copies! That is the point of the count meter.
May 27, 2014 | Sharp MX-2700N Color Copier
How to check the meter
just push the 0 key or cancel key, just try you can read the counter
Jun 24, 2013 | Sharp SF-2025/2030 Copier Toner Black...
Sharp MX M503N's touchscreen is frozen and saying
hi sir i clear our machine meter reading. please help
Nov 18, 2012 | Sharp Office Equipment & Supplies
Sharp copier repair code F5-02
Here is a list of all Sharp Copier Error Codes
The Sharp AR-M205 is almost 12 years old now. It will be very hard to find parts for that machine unless you can find a low meter on ebay.
You may want to take a look here at some of the current Sharp copier models. It looks like the Sharp MX-M232 replaced this machine.
Oct 29, 2012 | Sharp AR-M205 Copier
Sharp AR-M550U code:E7-03
The E7-03 error code means the HDD is not properly installed or is dead. You can check the connections on the HDD and the MFP Controll PWB. You can also use Simulation 62-2 and 62-3 to check the read/write of the hard drive.
Sep 07, 2011 | Sharp MX-2300N Color Copier
Meter reader for model Sharp AR 5316
Are you asking where to check the meter of Sharp AR5316, if so just press "0" but do not take off the pressing. Three digit will be shown and another three will follow. This constitutes the reading.
Nov 04, 2009 | Sharp Office Equipment & Supplies
I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Apr 15, 2009 | Sharp AR-235 Copier
277 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
