It takes a spark plug socket which is deeper than a normal socket you can get one at sears just ask them for help and they can show you which one you will need to remove the plug remove the rubber cap place the socket on the plug and in a counter clock wise motion remove the plug replace as needed then switch the wrench to tighten and in an opposite motion clock wise tighten just snug carefull not to over tighten just snug will do
For
spark plug problem, click the help links provided below: ---
Car has
no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How to Replace Spark
Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
Car cranks, has spark but
will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark
plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to gap spark plug ?
http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
How to identify number one
spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How does the spark plug
wire go on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
Spark plug Firing Order
Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
For
Car has
no spark?
Plugs?
will not start?
The spark
Diagram?
This will help.
Thanks.
For
Car has
no spark?
Plugs?
will not start?
The spark
Diagram?
This will help.
Thanks.
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
-----------This will help.Thanks.
For
Car
has no spark?
Plugs?
Car
cranks, has spark but will not start?
Diagram?
This will help.
Thanks.
For
Car
has no spark?
Plugs?
Car
Diagram?
This will help.
Thanks.
For
Car
has no spark?
Plugs?
Car
Diagram?
This will help.
Thanks.
