White knight c42aw leaking water underneath at the front... What could this be?
The pump motor housing is cracked
or the door seal is worn thru
you need to use a mirror and a light too have a good look with out too much effort
or lay the empty machine on its side
the opposite side from the soap drawer
to ident the source of the water
it could even be the drum hose connecting to the pump
or the O ring seal is missing from the pump filter tray securing screw {the big round white screw usualy behind a panel or flap if it has one }
Posted on Dec 04, 2014
5 Suggested Answers
reg501
  • 413 Answers
SOURCE: water is leaking from the underneath, at the front of the machine
The drain pump is located at the front, underneath. The drain pump has probably failed and will need to be replaced.
Posted on Jun 04, 2008
  • 23 Answers
SOURCE: My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Posted on Sep 14, 2009
beltronic205
  • 1460 Answers
SOURCE: i transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Posted on Apr 08, 2010
paulcharmbur
  • 744 Answers
SOURCE: Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Posted on Aug 05, 2013
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Code troubleshooting
White knight dishwasher flashing red light and. Won't. Empty .
could be something in drain pump need to bail the water out of dishwasher best way is a small scoop take filter out and you can get to the lowest point of sump. Take water out and use sponge for the dregs . Un plug appliance and turn water off remove inlet hose and waste pipe. Lay the appliance on its back and remove the base of the appliance you will then see the drain pump remove 3 screw and gently remove pump head and remove object but watch finger if it's a shard of glass .
Jul 15, 2014 | White Knight Press DW1260WA 600 mm White...
I can get the back of my white knight 38AW tumble dryer
try lifting the top of the dryer it usually pops up in the front then you will see the drum and the belt
Sep 27, 2012 | Abbaka White Knight 38AW Electric Dryer
Jul 16, 2012 | Hotpoint Washing Machines
I have a white knight WK447 with 2 buttons on the front. Which one do you push in to dry quickly please?
here is a website to download information on your dryer, Good Luck Tim:
http://search-pdf-books.com/white-knight-wk447-tumble-dryer-pdf/
Jan 16, 2011 | Dryers
My dryer is leaking water from the bottom of dryer
Check the vent coming out of the back of the dryer. Somewhere in the vent there is a blockage. If you clear the blockage you may solve the problem.
Jan 07, 2010 | Abbaka White Knight 44AW Electric Dryer
Leaking underneath
Maybe its not draining completely? Have you tried opening the front panel, pulling out the white plug, putting a bucket under it, unscrewing the front of the plug and checking the filter?
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak from my washer underneath i have a Whirlpool Duet SportĀ® HT 3.7 I.E.C. cu
Check the filter, as it may be leaking. To do so, take white panel off the front, put a bucket in front of the unit, unseat the rubber feet holding in the white plug and pull the white plug out, unscrew it, allowing water to run into the bucket, clean filter, check the gasket, as it may need replacement (if so, replace it), then screw white plug back in, push plug back into unit, secure the rubber feet, and replace the front panel.
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from back of m/c
You may have accidentally disconnected the pipe which takes water from pump to bottle.
Please post back if any assistance needed to access pump.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi TC7114W Electric Dryer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
