Low sound when spinning
My washing machine is working fine -but the problem i'm facing with it from yesterday is the sound is very low when spinning , and also when taking water and the sound is very slow when it is working. Please suggest me what is the actual problem with my machine.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Well the spinning mode engages the transmission, the clutch and if direct drive the motor coupler, may be u have a clutch going out or slipping and thus the sound but what kind of sound is it? oh if its belt drive they can make weird noises too.
Posted on Dec 05, 2014
Hoover 500mb washing machine doesn't 'click' through the cycles
Sounds like your timer is not working correctly. I would suggest replacing it, as there isn't a way to repurchase timers.
Oct 10, 2015 | Hoover Washing Machines
I started my washer and I worked just fine then it went into an extra rinse cycle and now it won't drain or spin the door switch works I can hear it click and then a low humming sound
Turn power off, then set the machine to a spin cycle, you may need to do this several times before the door will open. Hope this helps
Oct 08, 2015 | Washing Machines
My maytag performa pav 2300 is making a loud noise while its spinning. Sounds like metal on metal. Its working fine. Its just that noise. We just got a new motor yesterday. What could be the problem ?...
Hello
On this model washer the noise is most likely caused by a worn washer tub seal assembly. remove agitator (nut on the top under cap), spin basket and tub assembly. remove seal and install new one.
Nov 03, 2011 | Maytag Performa PAV2200
My washer stops at a certain minute and won't proceed (i.e., it stops at 11 minutes for the low extract spin only cycle). Very frustrated! It worked fine for the service guy yesterday!
it may be in its pause cycle the washer pauses for about 2 minutes during certain cylce allow the cycle to continue some cycles go between agitation and soak
Jul 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
Won't spin but everything else works fine.
hi..sounds like a rubber belt got too hot and broke.
Replace it with a new one.
check it out..
thank u..
kindly rate my response..
May 08, 2009 | Washing Machines
Kenmore 110 Heavy Duty 70 Series Washing Machine won't spin
Can you move the basket by hand...if so you need a basket drive. If not you have a bad clutch or gear case
Jun 07, 2017 | Kenmore 24032\24036 Top Load Washer
Whirlpool top load washer gets stuck on spin and stops
your lid switch is most likely bad.you can che.ck this by taking two screws from face of machine and flip face back.you will see a disconnect plug on machine that goes to your lid switch.unplug machine and unplug disconnect at top of washer under the face,you will need a jumper wire to put in 1st and 3rd hole in your disconnected.plug machine back in and see if it will go into spin.you can also put your finger on lid switch and push in on it and if you dont hear it clicking or if you dont see the finger to push in then it is definately lid switch.
Mar 06, 2009 | Whirlpool Washing Machines
Wash cycle operates on low loads only
This sounds like a classic capacator fault.
Nov 06, 2008 | Whirlpool AWM5104/1 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
