Question about Hoover Refrigerators
I have a problem with a Hoover HVNP 4587 black. After a 7 years of use, suddenly the temperature is very low with a result that I can not put nothing inside, like bottles of water, vegetables, foods e
Bring the temperature up and down. Nothing happens it continues to freeze everything
    Master:
  • 560 Answers
Make sure the coils are clean.
Posted on Dec 04, 2014
Suddenly stopped steaming, tank filled steam light stays on, no steam but heats up? Problem solving in manual just states the obvious? Can you suggest anything else or will I have to contact Hoover
Perhaps Element not heating to full temperature to generate steam.
Temperature sensor may be faulty if element is ok.
1 Element or 2 ????
Sorry... No magic fix button
Open it up and start testing things.
a multimeter comes in handy here.
or
back to Hoover repair centre
Good Luck
Feb 03, 2016 | Hoover Vacuums
Hi ive hoover hrfa54w fridge freezer just over a year old. Ive noticed freezer is starting to defrost sometimes the freeze again....its in a holiday cottage so often in a very cold ambient temperatur
Ambient temp will cause the thermostat some confusion. There's probably nothing wrong with the fridge, my freezer doesn't like being in the outhouse. Only alternative is only switch on when you are there or move it to a cupboard where you could put a low output source of heat just enough to keep it happy. Then get it out when you are there?
Jan 25, 2015 | Hoover Refrigerators
I need to calcualte 4587 mod 8 how do i do this on the casio fx-115MS? (there's no 'mod' button) Many thanks
The lack of a mod function makes this more than a bit painful. Here's one way:
Press MODE 4 to go into BASE-N (integer) mode. If the display doesn't read "Dec", press the x^2 key. Now calculate 4587-4587/8*8 (press 4 5 8 7 - 4 5 8 7 / 8 * 8 =, where * is the multiply and / is the divide).
You can calculate other mod problems the same way. a mod b is a-a/b*b.
Press MODE 1 to return to your previously scheduled calculations.
May 11, 2011 | Casio FX-115MS Plus Calculator
Brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
Apr 11, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
Mar 05, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Suddenly the automatic deterent mixing system in my hoover steamvac widepath (model F7443-940) stopped from working. It does not dispense detergent anymore. What could the problem be?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766252
Generic problem for all Vacuums
Suddenly the automatic detergent mixing
Posted by btaha on Jul 10, 2008
Suddenly the automatic detergent mixing system in my Hoover SteamVac WidePath (model F7443-940) stopped from working. It does not dispense detergent anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It could be the trigger assm could be broken and is not releasing the solution and or water, or the valve under the water solution tank is not releasing the solution. Please check with your owners manual in the trouble shooting manual or if you do not have a manual, call the Hoover factory cust serv and give them the brand name and model # so that they can send you a new owner’s manual. Your local vacuum cleaner dealer should be able to do a diagnosis of the problem and can give you and est of the repair. Or if the vacuum is less than one year it should be covered under the Hoover factory warranty. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
WASHES BUT WILL NOT SPIN
if it,s 7 years old. you,ve had your moneys worth. Scrap it and buy a new one.
as a repair solution, Check that the machine is emptying.
And that the pump has,nt got a coin/badge or anything else wedged in it.
Mike @ Compurepair.
Feb 25, 2008 | Washing Machines
Filter sucks against top creating low suction
Beckyanneok,
See my post with the same problem (described in painful detail) at:
http://www.fixya.com/support/t329235-no_vacuum
I've no idea why this should happen all of a sudden. But it has. And so far nobody is suggesting anything.
Don.
Apr 30, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Refrigerators Logo
64 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
