What should i do when my my micro bus 2.3 is getting hot?
    Sergeant:
  • 238 Answers
Check for dust. If you can open the system, vacuum it out. If not, you'll need compressed air, which you can get in a can if you don't have a compressor.
Posted on Jan 04, 2015
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
Hot bus bar YES! The Neutral bus bar gets HOT on
1991holiday ramble aumi lite when we pluged it in one of the wire was not wired right fix the wireing all works excepts the lights it blow all the bubs tryed new one the nights still will not work
Aug 05, 2013 | Cutler Hammer Electrical Supplies
Can't read micro usb drive
error 43 is a usb universal serial bus controller problem
click start control panel administrive tools ,computer management ,device manager scroll down
universal serial bus controllers you should see a yellow question / exclamation mark? ! or a red X
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
for windows 7 you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
Oct 14, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
Jun 04, 2012 | MSI Computers & Internet
My micro bus has no spark it is a 2-6
Immobilizer disable injector not spark,may sure the battery is sufficient to turn the car over,
Mar 14, 2012 | 2005 Volkswagen Microbus
The sound on my L7VMM2 motherboard is not working.
First of all which operating system is on the machine?
Secondly have you been into the BIOS to see if the on-board has been disabled. To get into the BIOS restart the computer and press either the Del or Esc key to access the BIOS.
Also go to device manager and see if the audio has been disabled from there.
If you have installed Windows 7 or Vista then there could be a chance that the motherboard drivers are not designed for the operating system. If that's the case then no driver will work.
You would have to manually search the internet for someone who may have found a compatible driver.
Regards.
Jul 22, 2010 | EliteGroup Computers & Internet
How to flash and unlock code for it
hi,
lets try to fix your problem without spending a single cents..removed your micro sd ,(small memory card of your phone) then scan it in computer,,by doing this you need an all in one card that supported mini sd,mini sd ,memory stick etc..then you will find if your micro sd is having a virus..back up your files then reformat your micro sd ,then after formatting back your files...without your micro sd open your phone ,if it is ok now ,so the problem is your micro sd...if still there the problem ,reset your phone by doing this ,type *#7370# and enter your locked code..wait until the phone reboot itself.
if not works we go to the second solution but you need this gadget and tools in able to fix your problem...
1.mxkey dongle activated
2.ufs interface
3.3110c fbus cable
*open mx key
*select BB5
*put the fbus cable in 3110c
*put the mcu ,ppm ,cnt ..(the flash file must be higher than former version to prevent damage on phones software ,the old version shall appear when you scan or bus check the phone..)
*bus check the phone
*back up rpl first in mx key
*flash the phone and wait until it is done..
goodluck and thanks for trusting fixya..
Jun 21, 2010 | Nokia 3110 Cellular Phone
When my 3110c phone on<its 3time on off and next time sucsessfully off...pls help me...
hi,
2.ufs interface
3.3110c fbus cable
*open mx key
*select BB5
Jun 20, 2010 | Nokia 3110 Cellular Phone
My fone is not switching onbut after few sec. it flashes on and off
hi,
2.ufs interface
3.3110c fbus cable
*open mx key
*select BB5
Jun 19, 2010 | Nokia 3110 Cellular Phone
I've got a micro bus with a 1800 jetta mark 2 motor convertion .My problem is that i do not get any spark to my distibutor .When i start my micro bus all it does is swing but does not start .I've put in a...
Um u would have to change the ECU. if the tone wheels for the cam or crank pulse width are not programmed to the PCM it will not deliver spark. See if you can get what is called a PCM intersepter and have a tune shop program it for u. It seem more like a software problem.
Jul 07, 2009 | 1995 Audi S6
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
