Question about Beko WM5140W
My washing machine fills up with water then goes no further
I cleared the filter
I think the heating element has an issue
i think its a cold water intake only machine
and youve set it too like 40deg wash or 30deg
but if the water doesnt heat up then the machine will be stuck trying to heat water and go no further
its one idea of a few
it could be the preasure switch
this is a job for the repair guy and show him this answer
Posted on Dec 04, 2014
How do I get into check the pump for blockages on my hotpoint wmud942 washing machine, the key symbol is on all the time with door locked, when a programme is running the pump starts but then when it
I would suggest you fill the washer with water externally up to below the door level and run it in one of the short wash cycles. I would assume it will progress further into wash. This would suggest the inlet water circuit has a fault. I am hoping the laundry water tap was turned on when you were running the washer.
Best to replace the inlet valve and see. Worth spending the 20 quid.
Hotpoint WMUD 942 UK Washing Machine Valve
Sep 07, 2014 | Hotpoint Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
Haier hwmp95tl washer
have you cleaned the filter
Jan 25, 2014 | Washing Machines
Asko W6021 won't fill. It clicks and starts, but no water fills drum. I've cleaned drain trap but don't know how to clean inlet filter as suggested in manual.
The water inlet filters are inside where the hot and cold water supply hoses screw into the machine. Turn the water off, unscrew the hoses and they should be visible. However it might not be those causing the machine not to fill. If they needed cleaning the water would fill- but taking longer each wash.
If you confirm the filters are clear, it is more likely to be symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, or the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 20, 2011 | Asko W6021 Front Load Washer
The hot water fills fine but the cold water just trickles in. The screen filters in the hoses are clear. Is there another screen filter on the cold water? Do I need a new inlet valve?
yes, there is another filter which you must clean. turn the water valve off, then remove the cold fill hose from the machine, and there is a small gauze filter in side the vavle from were you removed the hose, using a small pliers, pinch this little filter out, it will be full of limescale, wash it, replace it, put back the cold fill hose, turn water back on and select your programme. you will find that it is now working perfectly.
email me and let me know how it goes for you.
appliancesdav@hotmail.com
Feb 03, 2010 | KitchenAid Washing Machines
WASHING MACHINE FILLS WITH WATER GOES NO FURTHER
not too familiar, but just replaced my lid switch (but that worked) and thru my research I found could also be the belt, so try researching that, sorry could not be more help
Oct 07, 2009 | Roper RAS6233KQ Top Load Washer
Washing machine does not add any water
pop top up look for small hose going from bottom of tub up into console remove either end if water runs end ck hose for restriction if hose clear water level switch may be stuck in filled postion try tapping it if works replace it don't trust it to stay fixed
Nov 18, 2008 | Maytag PAV2300 Top Load Washer
Kenmore elite calipso wash motion
your inlet filter is most likely plugged.
take of your hoses from the machine and clear the filters in the machine inlet ports.
If this does not help your inlet valves are broken.
But most likely the filters is the good bet
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
Sep 18, 2007 | Washing Machines
Beko WM5140W Logo
144 people viewed this question
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
