Question about Electrical Supplies
How to connect one way Wilko dimmer switch?
There is L1 L2 and com. which one is earth? and where other wires go? thanks Denis
  • 3,382 Answers
The earth should be green the other two do not matter. They connect in the circuit the same as a normal spst switch.
Posted on Dec 04, 2014
Ive got a single dimmer switch with l1 and l2 which ones the live please
L1 L2 is usually for 240Volt with 2 Hot wires.
If dimmer is rated 120V or UK 230V, then usually Hot goes to L1 and Neutral to L2
Aug 12, 2013 | Electrical Supplies
What does L1,L2 and Top mean
The following should help with wiring your dimmer - all the other answers are referring to a car and no help whatsoever!
http://assets1.auroralighting.com/web/sku/66/general/instructions.pdf
Nov 14, 2012 | Cars & Trucks
I need to hookup up a Grasslin GM40 timer controlling one load and a 120vac application. Just wondering if someone could verify the hookup terminals as I cannot read the schematic as it is mostly gone. ...
Open following links to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM
GM40 can be used for 120V or 240V 277V applications for single-phase and some 3-phase applications.
For 120Volt, set all 4 dip switches to ON position BEFORE applying power.
ON position is pushed to left.
120Volt cable from breaker box has black hot and white neutral wire.
Black hot typically connects to terminal L1
White neutral connects to terminal L2/N
This action will power the time clock and relays.
Other terminals on GM40 are the relay terminals, and these terminals are dry.
Dry means they receive no power when wires are connected to L1 and L2/N.
There are two independent relays and each relay has 3 terminals: NC NO and COM.
If you are controlling one 120volt Load, then use one relay.
Run a jumper wire from terminal L1 to COM terminal.
So COM terminal is connected to Hot.
Cable going to 120V Load has black and white wire.
Connect black Load wire to terminal NO (normally open).
Connect white Load wire to L2/N.
Jul 19, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
I have a double switch with connections for 2 lights, one in one half of the room and the other in the other half On the back of the switches are com at the top of each and L1 and L2 at the bottom of...
If there are definitely 2 reds, 2 blacks and 2 earths it sounds like the cables are switch wires from each light. Switch wires are normally twin wires and contain only the red and the black. The person installing sounds like they have used a twin and earth. Anyway the red should go the common and the black to L1. The switch should work correctly. Do this for both switches. If the switch is on when the light is off put the black into L2.
Feb 10, 2011 | Electrical Supplies
I have bought Crabtree dimmer switch but it came without wiring instructions. There are 3 terminals, one marked L1, one L2 and the other with a wavy line with an arrow across it. Which one does the 'line'...
This is a 2way dimmer the wavy line is the common so your live supply will connect to this terminal .For 2way switching your strappers go in L1 L2 if you only require 1 way switching use either for your feed out to the fitting and disregard the spare terminal.
HTH
Oct 21, 2009 | Kitchen Appliances - Others
Bathroom pull cord switch i have L1,L2 and COM but i have 5 wires 2 red 3 grey what goes where?
You don't tell us where the wires come from. For instance if the red wires were from the power source, then those two red wires and the com would join. Then two greys would tie to L1 and the third would go to L2. This would give two intensities and off.
Posting a photo or having an electrician look at it might be a better idea.
If the reds and greys all come from the fixture itself it is anybody;s guess as to the connections.
Sep 25, 2009 | Electrical Supplies
L1, 2 and L3 versus COMM
what kind of light switch are you replacing??? assuming house light switch???
one way or two way switch??
I have not come across the type of switch before.
L1, L2 is just label as line 1 and line 2, comm is usually refer to common (ground wire-white).
is the red wire-hot???
Oct 23, 2008 | Electrical Supplies
Pull cord switch
If it is a 1 way switch circuit (2core +earth cable) it should be LIVE/HOT in COM and Aux live (to the light) in L1 . I
f you have a 2 way circuit (3 core + earth cable) the aux strappers go in L1 & L2. and LIVE/HOT to COM
Remember to disconnect the power before working on electric wiring.
Please remember to rate this solution.
Oct 15, 2008 | Electrical Supplies
Electrical Supplies Logo
78 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
