Question about Exercise & Fitness
Where can i buy a forerunner treadmill 2700 rear roller??
Rear Roller has a crack
    Master:
  • 560 Answers
Contact the manufacturer.
Posted on Dec 04, 2014
Rear roller makes noise
most likely the bearings are going bad.try loosing the walking belt and rotate the roller by hand. if you feel any grinding or its not smooth it shoud be replaced. normally only the two adjusting bolts hold it in there
Apr 19, 2014 | Golds Gym MAXX Crosswalk 650 Treadmill...
Nordictrack 3700 makes a knocking sound when I run on it
Hello.
Knocking noises more than likely come from the rear roller, there could be a small chance it's coming from the motor it's self though.
Have some walk on the machine and make the noise while you locate which end of the treadmills coming from.
If it is the rear roller the bearings will need to be replaced, this can be done by removing the rear roller and taking it down to any bearing shop and have them locate the bearing numbers. Ask them for advise on removing them as well.
If the noise is coming from the front of the treadmill then have a look at the fly wheel coming off the motor, locate grub screws and tighten.
GymWorld.net.au
Jan 11, 2014 | Nordic Track Nordictrack Track E 3700...
I need to replace the motor belt but i can't remove the front roller of my H140t Healthrider treadmill
There is one screw in the front roller
  1. Loosen the rear roller
  2. Remove drive belt
  3. Remove the 1 screw in front roller
  4. Pull roller out
Jan 01, 2014 | FreeMotion HealthRider "Club" Series H140t...
How to change belt
it's a big job, the front cover protecting the motor unit has to be removed, the rear roller has to be loosened inwards by using the large allen key to release the tension. The front roller has to be loosened and lifted out of the treadmill (it may need cleaned to take away any rust)
The rear roller can be lifted out and then the bed (running deck) needs unscrewed (allen keys) this should slide out. The new running belt should be put in place in the treadmill, place the front roller in place, the bed and the rear roller, fasten each of them up and adjust the rear roller so that the belt runs straight and it tight enough that when walking on it, you can't stop the belt.
Jan 17, 2012 | Life Fitness 9500HR Next Generation...
Treadmill walking belt is shifted
Turn left rear roller bolt in to approximate start positon, then Turn right rear roller bolt 1/4 turn counter clockwise. and repeat 2 more 1/4 turns if needed.
Dec 31, 2011 | Exercise & Fitness
Belt stops running although you can hear motor running. How do you replace front roller pulley?
Loosen off the rear roller adjustment bolts, 10 turns each side counterclockwise.
Remove the motor drive belt.
The front roller should now be removable. If you have difficulties, back off the rear roller adjustment bolts 3-4 turns further. Keep track of how many counterclockwise turns so you are able to readjust the belt after replacing the front roller pulley assembly.
Repeat the instructions in reverse once the front roller is in position.
Dec 16, 2010 | Epic View 550 Treadmill
The belt always moves to the right side
your roller ajustments are loose, loosing all the rollers front and back, re aline belt to center, tighten front roller first then tighten rear roller, Rear roller has 2 seperate ajusting allen bolts, 1 on each side, count the turns on each bolt when turning them inward, keep the count even turns on both allen bolts
Oct 24, 2010 | Proform CrossTrainer Treadmill
Replacing the drive belt Nordictrack 2900
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, kjosr@cox.net
Oct 24, 2010 | Nordic Track /proform Treadmill...
The treadmill is loose. How can this be fixed?
If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud, then find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability.
If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt Tighten the bolt and test. If the problem is not corrected, repeat steps above and retest.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. Follow this procedure:
First remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Rear Roller Adjustment Bolts
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley and front roller must be replaced.
Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud. Loosen the rear roller and remove the two adjustment bolts. Some models have a spring loaded tensioner on the right hand side so be careful when removing these bolts. After the bolts have been removed, remove the rear roller end cap(s). The rear roller should now simply slide out of the walking belt.
Remove the motor hood. Using a black permanent marker, make a mark on the front roller adjustment bolt on the motor compartment side at exactly where it fits flush with the roller so you will know where to retighten it later. The adjustment bolt is on the right hand side of the front roller. Then remove the bolt with a 7/16” wrench. then remove front roller and replace with new reverse procedure mentioned above
May 16, 2010 | Proform Sport 1000 Folding Treadmill...
Exercise & Fitness Logo
44 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
