Question about NetGear WG302 802.11g ProSafe Wireless Access Point with WG511 54 Mbps Wireless PC Card (WG302NAWG511KIT)
How do i connect my WG302 to my laptop using a console cable?
I followed the exact steps for connecting it because using the web browser didnt worked in the first place, but it just doesnt want to connect with the wireless router
  • NetGear Master
  • 3,497 Answers
If Windows
go to dosprompt on p.c or start run cmd <press the enter key>
type in ipconfig <press the enter key>
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ?
note the ip address of the laptop and the subnet mask
If the ip address is not 192.168.0.210 then go into the network settings and set the laptop up with 192.168.0.210 and then make it a static ip address.
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ? (if not restart the laptop ) and check again
Next question how did you connect the wg302 directly to the laptop was it directly connected or was it through a network switch or network hub. Most likely the Cable router or DSL router has a DCHP server assigning different ip address lease range. You can either change the ip address of the access point device to one in the original current router lease range and assign it as static for the wireless access point device in the dchp lease table or assign the wireless access point with the second ip address as an example 10.0.0.2 and make sure the router dchp server allocates above 10.0.0.20 then temporarily connect router to laptop and temporily set laptop with 192.168.0.210 and then log into access point and change ip address to 10.0.0.2 for wireless access point device and turn off its dchp server. Then change laptop to use dhcp while connected into network hub or network switch with original router and restart laptop wired back into original normal network.
Posted on Dec 09, 2014
My wireless router wont work
You need to (temporarily) hook a computer up to your router using an ethernet cable to set it up properly so you can send out a wireless internet signal with it. To connect to your router with a computer simply open your web browser and type in the router's address in URL web address bar. Consult your router's documentation to determine the exact address for your model. Note that you do not need a working Internet connection for this step.
Apr 10, 2014 | Linksys Wireless-G Broadband Router
My laptop wont log on to belkin
Sir,
Check your IP Address, Maybe its conflict with other device.
My advice to turn it automatically.
Or
Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router.
Perform the steps below to set up your Belkin router through the web-based setup page.
NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router
Step 1:
Unplug the modem and router from the power source.
Step 2:
Connect the modem to the WAN or Internet port of the router.
Step 3:
Power ON your modem first, then your router by plugging them back to the power source.
Manually setting up your router
Step 1:
Connect the computer to one (1) of the Ethernet ports of the router.
Step 2:
Launch a web browser and enter "192.168.2.1" in the address bar.
Step 3:
Click Login.
Step 4:
Leave the Password field blank and click Submit.
Step 5:
Under Internet WAN, click Connection Type.
Step 6:
Select your Connection Type, then click Next.
NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below:
Cable Internet Service
PPPoE / DSL
Static IP Account
Step 7:
Enter the details provided by your ISP and click Image.
You should now be able to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected.
You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices.
as mention On official Belkin website vedio for Belking Online Support:
Setting up the Belkin router using an iOS device Video
Belkin
Or
In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
Mar 07, 2014 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot set up belkin HDTV adapter F7D4555v1
You can also try to connect this device using a wired connection to your computer or laptop Running Windows 7 or Windows 8. The first thing to do, is make sure that you press the little reset button on the device so that the device memory is cleared. Then all you have to do is open up Google browser or Internet Explorer and type in 192.168.2.1 and hit enter, and that will bring you to the Belkin Setup Menu. From here you can add this device to any home or office network just follow the on-screen step-by-step instructions
Dec 27, 2012 | Belkin Computers & Internet
Sitting in a Starbucks trying to connect to Internet. Get error code 052211-1. Unable to connect settings and access points
The reason this is happening is because Starbucks makes you login to an account before you are able to access the internet. Unfortunately the DSi is unable to use this login page as the DSi does not have a web browser. However there is still a way for you to get online.
You will need
  • A laptop
  • USB Wi-Fi connector for the DS
Then just follow these steps
  1. Turn on your laptop and access the Starbucks Wi-Fi
  2. Plug the USB Wi-Fi connector into your laptop.
  3. You should now be able to easily play your DS online
Jun 13, 2011 | Nintendo DSi Black Console
Ip address failed
  • In order to connect your console to the internet you will need the following:
  • Laptop with WiFi
  • Ethernet cables
  • USB cable
  • Video capture card
Below are the steps involved includind some additional information:
    File Sharing
  1. Step 1 Go to Settings in the PS3 menu and scroll down to Network Settings. Go to Internet Connectionmag-glass_10x10.gif Settings and select your wireless router from the list of available connections. If the router has security, you must input your password. Internet Connection in the Network Settings list will say "Enabled" once you are connected.
  2. Step 2 Link the laptop and PS3 together through a router if you have one. Connect both the console and computer to the router with Ethernet cables. This is needed for a PS3 with 40 gigabytes of memory and that does not have WiFi.
  3. Step 3 Connect the devices directly with a USB cable. Use one of the USB-style ports the PS3 uses for its game controllers. This requires a USB cable with two thin connector plugs.
    Connecting to a Monitor
  4. Step 1 Purchase an external video capture card for your laptop. This device will connect to the computer through the USB port and will have both composite and S-video connections.
  5. Step 2 Connect the capture card to your laptop. Insert its included CD-ROM into your disc drive and install the software on it that allows the computer to recognize the card's drivers and includes a video viewing/editing application.
  6. Step 3 Attach the PS3 to the capture card using the console's RCA composite cable. Open the video application and turn the console on to view it in the program's screen.
  7. Step 4 Locate and click the application's "full screen" button to enlarge the game screen to your full monitor. THANKS. MIKE
May 04, 2010 | Sony Playstation 3 (PS3) Console
I installed my D-Link DIR-615 router today and did my setup in my Window 7 laptop. I don't know whether it matters whether I do setup in a laptop or a desktop. Then, I connect the modem/router to my...
If you have trouble connecting to your modem, you may need to lock the speed down on the WAN port of your router to 10Mbps. Within the web-based configuration utility for the router, go to Tools > Misc and the option to select the WAN speed will be towards the bottom. Not all routers have this option.
Follow the steps configuring the router once again...
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router.
Step 2 Click the Setup tab and then click the Internet button.
Step 3 Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address from the drop down menu. Click Clone Mac Address. Click on Save Settings to save the changes.
Step 4 Click on Status. Under WAN, Click DHCP Renew. If it does not get an IP address or times out, then continue with the next step.
Step 5 Power cycle the cable modem and router using the following steps:
Turn the cable modem off (first)
Turn the router off
Leave them off for 2 minutes**
Turn the cable modem on (first)
Wait until you get a solid cable light on the cable modem
Turn the router on
Wait 30 seconds ..
Step 6 Follow Step 1 again to log back into the web configuration. Click the Status tab and click the Device Info button. If you do not already have a public IP address under the WAN heading, click on the DHCP Renew button.
Jan 22, 2010 | D-Link DIR-615 Wireless Router
I have DWL2100AP i can open the IP address
To enter the menu of your device follow the following directions :
Your device default IP is 192.168.0.50 - Connect the device to your computer with an ethernet cable and set up your computer IP address manually, make it 192.168.0.49 , subnet 255.255.255.0 When connection is established, enter 192.168.0.50 in your internet browser, you will be able to reach the console.
Nov 08, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
I need help to connect my Linksys WRT54GS router.
you connect your caple from your provider and all connections to your station then start setup by going to the browser and typing 192.168.2.1 for setup you can download a step by step instruction from LINKSYS
Nov 07, 2009 | Linksys Wireless-G WRT54GS Router...
Some websites don't work on wireless - on LAN cable all fine
Hi, please login to router configuration page and reduce the MTU to 1400
Hope, this helps.
Sep 22, 2009 | NetGear WGR826V Router
WEP KEY
disabling WEP security is not a great idea, unless you plan on replacing it with WPA. As for your request, please open a Browser and enter 182.168.1.1 into your address bar and hit enter. I can't seem to recall exactly where the setting is, but you will come across it if you look through the router admin page. Hope this helps.
Dec 21, 2007 | Computers & Internet
Computers & Internet Logo
107 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
