Question about 2006 NPR
2006 isuzu npr 5.2 diesel head cylinder bolts torque steps and spe thanks
    Problem Solver:
  • 13 Answers
Here is a link to a site that list the torque specs and steps for just about everything that requires a torque sequence.Hope this helps you out.
http://olybrake.com/pdf/fel_pro_torque_specs_guide.pdf
Posted on Dec 09, 2014
SOURCE: Torque spec for flywheel bolt: Isuzu 2.5 diesel engine
normally 110 nueton metres. use nut lock and once you have torqued you will feel if you have to tighten it a bit more.
Posted on Aug 15, 2008
SOURCE: what is the 98 isuzu rodeo head bolt torque
joyce, there are different specs for sohc and dohc engines. my advice is to get a Haynes manual from the auto parts store.
doug
Posted on Sep 01, 2008
SOURCE: Angle Torque settings head bolts
Use new bolts, tighten in the following stages 1. 20Nm 2. 100Nm 3. wait 3 mins 4. slacken bolts 1&2 retighten to 20Nm +110 degrees 5. carry out stage 4 for bolts 3,4,5 & 6 then bolts 7,8,9 &10 Sequence, 8 4 1 5 9 7 3 2 6 10 Bolts 9 & 10 are flywheel side of the engine.
Posted on Mar 17, 2009
c17hydro
  • 2984 Answers
SOURCE: cylinder head torque settings 1990 2.6L isuzu motor
From front to back is this:
7 3 1 5 9
8 4 2 6 10
First torque value is 58 ft lbs.....then final torgue is 72 ft lbs.
Posted on Mar 21, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
What is the cylinder head torque settings for a isuzu kb250 2006
new bolt 21.7-36.1ft/lbs first step, 59.4-66.5ft/lbs second step
reused bolt 57.9-65.1ft/lbs first step, 72.4-79.6ft/lbs second step
Aug 05, 2014 | Isuzu Pickup Cars & Trucks
Cylinder head bolt tightening sequence for isuzu rodeo 1998
1998 Isuzu Truck Rodeo 2WD 2.2L MFI DOHC 4cyl
The Head Bolt Torque
Torque sequence ----------------- front ' 7 3 1 5 9 ' of ' ' engine ' 8 4 2 6 10 ' ----------------- Step 1: torque bolts in sequence to 18 Ft/Lbs Step 2: turn bolts in sequence an additional 90-degrees Step 3: turn bolts in sequence an additional 90-degrees Step 4: turn bolts in sequence an additional 90-degrees recheck final torque in sequence
1998 Isuzu Truck Rodeo 2WD 3.2L MFI DOHC 6cyl
Torque sequence -------------- front ' 6 1 3 7 ' of ' ' engine ' 5 2 4 8 ' -------------- Step 1: torque to 20 Ft/Lbs Step 2: torque to 47 Ft/Lbs recheck final torque in sequence
Jan 15, 2013 | 1990 Isuzu Spacecab
2002 nissan maxima 3.5 cylinder head torque
Hi there:
Fig. Cylinder head bolt loosening sequence - Altima & Maxima 3.5L engine
Install the cylinder head bolts and torque in sequence as follows:
  1. Step 1: 72 ft. lbs. (98 Nm).
  2. Step 2: Completely loosen all bolts.
  3. Step 3: 26-32 ft. lbs. (34-44 Nm).
  4. Step 4: plus 90-95 degrees clockwise.
  5. Step 5: plus 90-95 degrees clockwise.
Fig. Right cylinder head bolt torque sequence- Altima & Maxima 3.5L engine
Fig. Left cylinder head bolt torque sequence- Altima & Maxima 3.5L engine
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Feb 17, 2012 | Nissan Cars & Trucks
Torque setting head 2002 nissan maxima
Hi there:
Thank you for using FixYa, have a nice day.
Feb 17, 2012 | Nissan Maxima Cars & Trucks
Whats is te cylinder heads torque for suzuki aerio 2.3 lts
Hi! Please don't forget to rate! Thanks!
Cylinder head bolt torque sequence-2.0L and 2.3L engines
Apply engine oil to the bolt threads and tighten the cylinder head bolts, in sequence, using the following 6 Steps:
  • Step 1: 38.5 ft. lbs. (53 Nm)
  • Step 2: 61 ft. lbs. (84 Nm)
  • Step 3: Loosen all of the cylinder head bolts
  • Step 4: 38.5 ft. lbs. (53 Nm)
  • Step 5: 76 ft. lbs. (105 Nm)
  • Step 6: Bolt M6 (bottom left of cylinder head) - 8 ft. lbs. (11 Nm)
May 12, 2011 | 2003 Suzuki Aerio
Correct pressure for torque the head of mazda pickup 1998
Since you didn't say which engine you have, I've pulled torque specs for 3 different engines. Also, since I can't include a diagram showing the relative locations of the numbered head-bolt locations, it would be a good idea for you to purchase a vehicle specific repair guide that will show this info.
Take particular note about the TTY (Torque to Yield) bolts used on 2 of the 3 engines shown. It is said that new head bolts MUST BE USED when head is replaced or re-installed to obtain the proper torque.
B2500 4 Cylinder
Torque sequence: --------- ' 10 6 2 4 8 ' front ' ' ' 7 3 1 5 9 ' -----------Step 1: torque in sequence to 51 Ft/Lbs Step 2: torque again in sequence to 51 Ft/Lbs Step 3: final tighten all bolts an additional 90 to 100 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
B3000 3.0 6 Cylinder
Torque sequence ---------- ' 6 4 2 8 ' ' ' ' 5 1 3 7 ' ---------- Step 1: torque to 59 Ft/Lbs Step 2: loosen in sequence (1) full turn Step 3: torque to 41 Ft/Lbs Step 4: torque to 73 Ft/Lbs
B4000 4.0 6 Cylinder
Torque sequence --------- ' 5 1 3 7 ' ' ' ' 6 4 2 8 ' --------- Step 1: torque cylinder head bolts in sequence to 26 Ft/Lbs Step 2: torque cylinder head bolts to 56 Ft/Lbs Step 3: turn cylinder head bolts in sequence an additional 90-degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
Good luck with this job!
Feb 06, 2011 | 1998 Mazda Pickup
What is the right Torque Specification of the cylinder head bolt,main bearing and connecting rod bearing for a 1997 Ford F 150 4.2 liter? Thank you...
Cylinder heat bolt torque:
Torque sequence --------- front | 7 3 1 5 | | 8 4 2 6 | --------- Step 1: Torque all bolts in sequence to 14 Ft/Lbs Step 2: Torque all bolts in sequence to 29 Ft/Lbs Step 3: Torque all bolts in sequence to 36 Ft/Lbs Step 4: in the sequence, loosen the cylinder head bolts three turns. Step 5: Tighten short bolt to 15 - 32 Ft/Lbs Step 6: Tighten long bolt to 30 - 36 Ft/Lbs Step 7: Tighten all bolt to 175- 185 degree note: Do not loosen all of the cylinder head bolts at one time. Each cylinder head bolt must be loosened and the final tightening prior on the next bolt in the sequence.
Main bearing torque:
Torque sequence: Step 1: torque bolts to 91 Ft/Lbs with the exception of the rear main bearing cap Step 2: torque rear main bearing cap bolts to 88 Ft/Lbs Step 3: torque brace bolts to 40 Ft/Lbs
Connecting rod torque:
Torque sequence Step 1: Torque to 29 Ft/Lbs Step 2: Turn an additional 90 degrees
May 17, 2010 | 1997 Ford F150 Regular Cab
Head bolt tourqe settings on a toyota cressida
Cylinder head bolt removal sequence
Removal sequence: Front 3 7 11 13 10 6 2 1 5 9 14 12 8 4
***CAUTION*** The above sequence must be followed during removal as to avoid warpage of the cylinder head unit
Reverse sequence to install, Step 1: Torque to 10 Ft/Lbs Step 2: Torque to 18 Ft/Lbs Step 3: Torque to 25 Ft/Lbs Step 4: Turn an additional 90 degrees Step 5: Turn an additional 90 degrees Step 6: Torque the 2 recessed 8mm bolts to 13 Ft/Lbs *** CAUTION *** engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper Torque
Don't forget to rate this answer, Good Luck
Apr 24, 2010 | 1992 Toyota Cressida
Head bolt toqure
Hope this helps, from autozone site. Curt
Application:
Note :
Torque sequence:
front | 3 1 6 |
of | |
vehicle | 5 2 4 |
Step 1: Lightly oil cylinder bolt threads & washers
Step 2: Torque to 22 Ft/Lbs
Step 3: Torque to 51 Ft/Lbs
Step 4: Loosen all bolts 180 degrees
Step 5: Loosen all bolts 180 degrees
Step 6: Torque bolts 1 & 2 to 25 Ft/Lbs
Step 7: Torque bolts 3, 4, 5, 6 to 11 Ft/Lbs
Step 8: Turn all bolts an additional 80 to 90 degrees
Step 9: Turn all bolts an additional 80 to 90 degrees
*** CAUTION ***
replaced or re-installed to obtain proper Torque.
Apr 24, 2009 | 1995 Subaru Legacy
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
2006 NPR Logo
670 people viewed this question
Top Isuzu Vehicle Parts & Accessories Experts
Randy Ohler
George Agios
George Agios
SriPhi
Are you an Isuzu Vehicle Part and Accessory Expert? Answer questions, earn points and help others
