Question about Tops Business Forms Office Equipment & Supplies
How do I terminate a protection order filed in behalf of me after I turn 18 in 2 months?
  • 778 Answers
Hello, I would first go and talk to a lawyer. The first consultation is free. You will probably have to go too court to legally do anything.
Posted on Dec 12, 2014
LEATHER MOTORCYCLE VEST I ORDERED FROM HIM AND NEVER RECIEVED THE MERCHANDISE
A.) contact the seller and notify them that you did not receive the purchased item
B.) if seller does not respond to your satisfaction, file a complaint with organization it was sold through (Ebay & PayPal, Amazon, etc.)
C.) if it was not bought through a place that provided protection, and you used a credit card, your card "should" protect you unless it was under $50
D.) if it was a bank card (debit) it is anyone's guess if you have any protection (my bank never offered any until just the past month). Check with your bank if this is the case.
/make sure you wait at least 3 days for the seller to respond, especially with the holidays/weekend here!
Nov 13, 2014 | Computers & Internet
Protect mode?
You added speakers in parallel which reduced the effective impedance to to a value low enough that your Rockford Fosgate amplifier had to enter protect mode to prevent damage to its output stages.
Jan 22, 2014 | Car Audio & Video
No spark to plugs 1999 ford f150 4.6l
https://s21.postimg.org/wwpncpluf/pcm_power_relay.jpg
Click on the link.
Voltage for fuse 18 comes from, pcm power relay.
Terminal 30, load side of relay is fuse protected and hot all the time. If you unplug that relay and use jumper wire between terminal 30 and 87, fuse 18 should go hot. That should mean, the control side of relay has a problem, The control side needs voltage and ground.
Jul 24, 2017 | 1999 Ford F150 Regular Cab
I cant download anything, Adobe says file damaged
Check the setting on your antivirus software if the detect setting is high it could see most file as virus and in order to protect the system may terminate your downloads.
However if its a particular file you are having problem with downloading, it could be a promblem from your ISP. There may be some rule or something that is blocking the download from there server.
May 15, 2012 | HP Computers & Internet
Video recording problem
When your battery gets low, the videos get progressively shorter in order to save what battery power you have remaining. When the camera starts turning off like this, it's time to recharge or replace the battery.
Jun 24, 2010 | Nikon D90 Digital Camera with 18-105mm...
The starter overload has melted!!!!! the fridge ran for 2 hours not cooling then stopped has not started since this fridge was turned off for 18 months compressor motor could survive this???
The start relay device is known to break down and can do so without damaging the compressor. About all you can do is replace the two parts and test it. Be sure to clean the compressor terminals for good contact when replacing the parts.
Jul 14, 2009 | Kenmore Refrigerators
Let our Experts solve your "My amp lights up like normal then protection light red comes on and turns the amp off resets and tries again. What would be my course of action
disconnect all wires (including RCAs)
reconnect positive, ground, and remote.
Turn amplifier (car) on.
If it goes into protect mode again - there is an internal fault that requires professional repair.
If the amplifier idles as normal - turn off the car. Plug in RCAs & re-try
Failure? - replace RCAs as they may be pinched or faulty.
Lastly if all connections are made and amplifier idles without going into protection - you need to concentrate on your load (subwoofers).
Be sure they are wired properly into a resistance that amplifier is rated.
The lowest impedence that amplifier is rated is 2ohm.
That is possible with (2) 4 ohm subwoofers wired in parallel....
(4) 8 ohm subwoofers wires in parallel...
(1) Quad 1 ohm subwoofer...
or (1) Dual 4 ohm voicecoil subwoofer.
Any other combination will result in an impedence too low for your amplifier.
Next:
Using an OhmMeter (Digital multimeter set to Ohms 20) test each voicecoil against its advertised resistance. It should be CLOSE +/- .5 Ohms.
Any other reading means the voicecoil is blown.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 27, 2009 | Kicker (ZX750.1) Car Audio Amplifier
Deleting stompsoft virus x-terminator
it is likely that the file IS in use by the computer..
have you tried the following >>
press and hold Ctrl - Alt & Delete (then release together)
this will activate the TASK MANAGER
Look in the PROCESSES area, and look for anything that looks like the name of the stompsoft program - select end process.
Do the same in the Applications Tab...
Click on the START button on the task bar
Select RUN
Tyoe msconfig
6th tab along says - startup.. Look for anything relating to stompsoft, and DESELECT IT.
Now try and remove what you need to remove..
Aug 16, 2008 | StompSoft Virus X-terminator (03032) for...
1,682 people viewed this question
Top Tops Business Forms Office Equipment & Supplies Experts
john h
 steve
steve
Are you a Tops Business Forms Office Equipment and Supply Expert? Answer questions, earn points and help others
