Question about GE SpaceMaker Microwave Ovens
Get a pictorial of the inside of the microwave where the capacitor is in a jvm1650
I need a good picture of the area where the capacitor is and the wiring around it.
  • 3,961 Answers
If I'm going to reply at all, I have to warn you not to go near the insides of a microwave unless you understand how to discharge the HV capacitor. It can hold lethal voltage even when the oven is unplugged. Do not depend on a self-discharge resistor, it may be faulty or not there.
I can't find a photo of that particular model, but here is one of a typical layout.
http://www.appliance-repair-it.com/images/microwavelayout.jpg
The HV capacitor is typically a metal can about 5" long, like this
http://thumbs4.ebaystatic.com/d/l225/m/m95TA3ZdkVPdKC7vYn0zvog.jpg
It may also be cylindrical.
Posted on Dec 04, 2014
Why wont my GE Spacemaker JVM1650 turntable wont work?
replace the turntable synchronous motor
look to ebay search for
ge jvm1650
then add turntable motor or browse down youll find a new motor
the coils inside may be duff
Aug 12, 2014 | GE Profile Spacemaker Over-the-Range...
LG Microwave not heating
there are two censors inside one high heat one low heat they can be checked with a meter if both are good its a bad magnatron and exceeds its worth
Mar 05, 2013 | GE JVM1650 1000 Watts Microwave Oven
My model#JVM1650CH03 will run for a few seconds,then I smell smoke and the circuit breaker in circuit box pops,can reset and same thing happens.
This is one of three things. The capacitor, the diode or the generator. Since it involves high voltage and microwave radiation,l dont recommend that you do this repair yourself but you can . If you need further information please post
Aug 10, 2012 | GE JVM1650 1000 Watts Microwave Oven
GE spacemakerXL microwave JVM1650 w touch screen Hi speed not working on external vent fan
It seems like the control panel is malfunctioning. The censorfor external vent fan may not work due to faulty control panel. You need toreplace the control panel, so that microwave will work properly. Replacing anERC is not a difficult repair and can be accomplished by the average do-it-yourselfoffer. Hope this will help you. Good Luck.
Aug 06, 2011 | GE JVM1650 1000 Watts Microwave Oven
Can you tell me where the fuse is for model number JVM1650
under the outer cover inside the unit in a fuse holder,make sure to discharge the hi-voltage capacitor before replacing or touching the fuse,being its the fuse it very well could be the hi-voltage cap that caused the fuse to blow
May 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Why does the fuse inside of the microwave keeps blowing
The fuse is protecting the unit from over heating and catching on fire. Either the electrical circuitry is bad in the unit or in the outlet you are using. You can test the outlet with a voltmeter to test the outlet to see if it is good or try another similar type of appliance. Chances are, it is the microwave.
Nov 07, 2009 | GE JVM1650 1000 Watts Microwave Oven
GE SPACEMAKER JVM1650 ''MICROWAVE MAKING LOUD HUMMING NOISE AND INSIDE REAL HOT WHEN DOOR CLOSED''WHEN DOOR OPEN DON'T HUM
When door open the microwave should not work at all, if the turntable and light come on with the door open , if they do , then this is an additional problem with door switch and must be fixed.
Regarding humming noise and no heath, Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 Microwave Suddenly Stops
Tami,
It isn't really difficult to replace... It's the 4000 Volts that go to it and the stored energy (voltage) in the high voltage capacitor that concerns me as far as telling you that it is a do it yourself repair. Also, and this a huge concern, is that after the magnetron tube is replaced, the microwave should be leak checked. A microwave leak detector that is certified is around $400. Now that I said that, I have rarely ever had one that leaked, but it is the law and that's the main reason that it needs to be done. I highly recommend calling GE Factory Service 1-800-432-2737 (1-800-GE Cares) to install the magnetron tube.
Brian
Jan 15, 2009 | GE JVM1650 1000 Watts Microwave Oven
Replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
Dec 28, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
Apr 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
