Hard disk is not working in dvr
Sir, i have pinetron 16 channel dvr and getting only hard disk problem. iam inserting new hdd but only searching indication work but getting check the disk, 4 to 5 hard disk i have change but display show same that check the disk. pls help and sort out my problem. thanking you
  • Televison & ... Master
  • 10,291 Answers
The software to run the DVR was also on the original hard drive. Once you change it , that is gone. You'll need to contact the manufacturer for a proper replacement.
Posted on Dec 05, 2014
I have a 16 channel dvr, tf 960H hd d1 dvr, it just stop recording, nothing wrong with harddrive, settings setup to record, but still doesn't want to record.
What's the status of the HDD? Enter Menu > HDD > General. The HDD status should be either "Normal" or "Sleeping", if there´s a problem you may get "Uninitialized" or "Abnormal", so you will need a new HDD, and you may need to initialize it before use. You can find a complete manual at http://files.cctvstar.com/download/User_Manual_of_True960H_DVR(V1.0).pdf
Jun 29, 2016 | Home Security
Flashing red cassete light mean
So.... Who uses a VCR any more. They are ancient history.
They don't last forever so perhaps it's time to think ahead....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. I got him a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Cheers
Good Luck
Maybe you can get a little more life out of that VCR still
Aug 15, 2014 | Toshiba W522 4-Head Hi-Fi VCR
Panasonic troubleshooting
I guess you mean a Set Top Box to convert digital TV transmission to old analog TV. Choose the correct video format for your screen.
Ah... Perhaps Your recording at an old standard & passing it to a modern TV or HD TV with the digital output from 1080 HD to 720 or lower still.
OR
Get a Digital Hard Drive recorder.....
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
Main Features:
HDMI Digital Output
Parental Control
Built-in WiFi
Network Playback
USB 2.0 Interface
Aug 14, 2014 | Panasonic Televison & Video
I forgot my password how can i reset it.
hay ya m8 you will need some sort of firmware on the hdd most times for it to work if you can get to menu settings see if you can formatt the hdd and see if that works if not get back to me and ill see if i can find a link for the firmware for ya hope this works for ya
Jul 01, 2014 | Digital Peripheral Solutions Q-See...
M Brand new DVR doesn't recognize its SATA hard disk? I have confirmed there is power on Hard disk. when it was not working. I format it by using windows 7 and reinstall it . what the reason?
is this the hard drive you recieved with the DVR? it is possible that the HDD is set up in the wrong format. windows sets up your HDD in a NTFS format which is compatible with most DVR's but i know there are some EverFocus units that read the HDD in a diffrent format. if this is the case you need too check in your owners manual in the HDD section, it should tell you what format it records onto, then place the HDD in your PC and reformat it to the right one.
Nov 03, 2013 | EverFocus EDVR16D1/500 16 Channel, 120...
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
My echo vue 805 DVR won't stay on and then it has hdd failer
If it says its got a HD failure, I would believe it. Since the OS loads from the Hard Drive, it is designed to shut itself down when drive faults are detected. I would suggest contacting DirecTV to discuss getting it replaced.
Mar 19, 2009 | Televison & Video
After recording a one hour episode, won't recognize the dvd.
Try inserting your DVD media into the PC and doing a 'quick format'. The LG is not seeing what it considers to be media that it can use. It is not seeing that you have inserted recordable media. Sometimes you can reformat the DVD or do a quick media erase, and the LG can then put on its blank "squares" that is uses for its menu selection. I think that it what it does when it 'initializes' a new media.
tom
Apr 23, 2008 | LG DR787T DVD Recorder
Help me!
I have strongly recommended that change your power supply with the same specification voltage and amp. I have installed so many GE DVR's most of DVR's restart when the power supply is not working properly or HDD have bad sectors. I also recommend use the scan disk on you HDD for proper checking of your HDD.
FROM
AI
Jan 29, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
