Question about LG WM0742H Front Load Washer
My lg wm0742hga front load washer machine over fill of water.
Error code iE, I check the pressure switch, water valves etc.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
Contact the manufacturer
Posted on Dec 04, 2014
What does it mean when it says PE on my lg wm0642hw washing machine
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Jul 29, 2016 | LG 4.0 cu. ft. Front Load Washer, White -...
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
Hello Felipe;
My name is Peter. I am a retired field service appliance technician.
The LE error code stands for "Locked Motor Error." This is one of the more common error codes on LG washing machines. Ii is a fault condition. Read your manual where it explicitly tells you to use only High Efficiency (HE) detergent. Although, regular detergent is less expensive, using other than HE, you are going to continue to have problems. Such as premature drum bearing failure.This is an expensive repair.
In the LG washer, the LE error code is usually caused by the burned out hall effect sensor, Part Number: 6501KW2002A.
1.) Unplug your unit and remove the back cover.
Be absolutely certain that the HALL EFFECT SENSOR is installed correctly. Three white plastic tabs on the STATOR (motor) securely hold the sensor in the correct position. If any of the *three plastic tabs* were damaged during an attempt to remove the old sensor-this will require replacing the STATOR ASSY
Also, Check for any black marks on the wires or burns or broken wires.
Dec 04, 2014 | LG WM0742H Front Load Washer
My lg wm0742hga front load washer machine over fill of water causing to leak out from the door
even when overflowing it shouldnt leak from the door? less u have a bad door seal? the water problem may be due to a bad water inlet valve? have u notice water in the tub even when ur not using it? check with a multimeter the inlet valve and the water pressure switch? blow into the water pressure switch while it is in the wash mode filling with water and if it starts washing the diaphfram is good if not its faulty. u can also checl the water inlet valve the one with the hoses attached . by running either a hot or cold cycle only and turn off the hot then turn off the cold? see if it continues to over flow with each cycle? hot then cold- GOOD LUCKKKKK
Dec 04, 2014 | LG WM0742HGA Front-Load Steam Washer with...
IE error code
Water inlet error - washing machine failed to fill
The fault code is displayed, if the washing machine does not detect any incoming water.
·Check wiring to water inlet valve
·Check water valve
·Check drain pump
·Check pressure switch
Check PCB
Oct 05, 2014 | Daewoo DWDWD3011WW Front Load Washer
What fault code ie
The IE or water inlet error or fault code is to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Sep 12, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Ie code comes up washer wont fill up
An 'IE' error code on the display indicates an inlet error, or that the washer was unable to fill with water within a determined amount of time. Before replacing the water valves, check that there is not blockage at the valves. turn off the water, remove the water supply hoses from the valve, and see if there is a build up of sediment, rust, etc on the valve screens. If there is, you can remove the little screens and clean them. If all or any filter screens are ok, replace the valve assembly.
Apr 09, 2014 | LG WM1814CW Front Load Washer
What is problem code IE and how do I fix it on my LG front load washing machine?
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. if this doesn't help then there are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg
Hope this helps.
Mar 09, 2011 | LG WM-2277HW Front Load Washer
What does IE on the display mean?
IE means inlet error. Most likely the washer took too long to fill, due to a plugged screen where the hose attaches to the inlet water valve. Frozen water line would do it also. Or a bad water valve.
Dec 05, 2008 | LG WM1814CW Front Load Washer
Lg washing machine error code is ie
IE = inlet error. Washer has not detected enough water after 8 minute fill time. Check screen at inlet water valves where hoses connect to machine for blockage. Look for kinked hose(s). Make sure there is water supply reaching machine. If all OK, most likely next thing is the water valve itself.
Sep 02, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM0742H Front Load Washer Logo
48 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
