Question about Samsung SyncMaster Computers & Internet
My Samsung Monitor when turned on it is flashing, can't use computer
I have the Mini Mac, and the electricity sent off and when I turned the computer on again, it started flashing
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
You need to give a bit better details as to what is happening
Posted on Dec 04, 2014
  • 10406 Answers
SOURCE: Samsung monitor randomly flashes black
> brand-new out-of-the-box
Presumably, it has a "warranty".
So, take it back to where you bought it, and demonstrate the problem to them, and make them repair/replace it, under warranty.
Posted on Aug 23, 2010
budmrtn
  • 11361 Answers
SOURCE: screen was very strange looking, with nothing but
I would try this with PC first or another MAC to make sure it is not video card problems.
If it still bad you may have to inspect the caps just like all failed VIEWSONIC as shown here.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 17, 2010
  • 661 Answers
SOURCE: LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
Posted on May 12, 2011
ynogami21
  • 670 Answers
SOURCE: My LG 1715S monitor that
Normally the option to reset the monitors default settings is available on the On Screen Display.
Try to Go to Menu look for Advanced Menu or any of that sort and the choice to reset it to factory default should be there.
Otherwise a hardware problem with the color mixer is the cause and that would have to be sent to the service center for repairs.
Other things you can try is to swap cables and try it on a different computer or a TV box.
If the same result happens then definitely it's the color mixer that has gone bad. Maybe it tripped or the part already given up.
You can try contacting LG through 1 (800) 243-0000
Hope this helps!
Posted on Jul 17, 2011
  • 3 Answers
SOURCE: tmy monitor shows the images only for 20 seconds, then it turns black.
Hi hope your monitor issue has resolved. I would suspect the problem is a hardware issue then a software setting. Since the monitor is over three and half years old, if your monitor is a LCD with CCFL back light and had been used almost every day, there may be 3 possible hardware issues. First is the internal power supply, that can go wrong due to heating problem within the monitor, this problem usually cause the monitor to display poor quality picture and may show interference lines on screen prior failure. Secondly, it may be the inverter that drives the back light, which may fail due to the safety circuit kicks in, because it involves with high voltages. Thirdly it may be the backlight itself, which is like most compact CCFL energy saving lamps that flickers or turn itself off when it reaches the end of its service life. This problem usually caused the monitor to show redness or yellowness images prior failure.
All of these can be resolved by qualified electronic repairers, all the best.
Posted on Feb 22, 2012
My Insignia Monitor doesn't work with my laptop, I've tried everything, from pc settings to cables, etc, i only receive a NO SIGNAL ad
Usually you have to toggle the display output on the laptop. The FN key + one of the F# keys with a monitor icon on it. Toggle it until it outputs to the monitor. Your getting "no signal" because no signal is being sent to the monitor or you have the monitor on the wrong input if it has multiple inputs.
Dec 24, 2012 | Insignia Computers & Internet
I want to transfer photos from attachments to e-mails on my Samsung phone model SGH - F480 to my Mac mini computer
Have you tried USB?
How about accessing your email account from the Mac and transferring that way?
Dec 14, 2012 | Apple Mac Mini 2.66GHz Intel Core 2 Duo...
Need to connect hp pavilion vf15 monitor to mac computer
First of all, before you look which one to buy, you need to find out which Video Port does you Mac has, i.e. VGA or DVI or Mini DVI or HDMI. Once it's confirmed, you have to find out the same with your monitor, so that you can buy the appropriate cable.
Pictures Below:
1. VGA
2. DVI
3. Mini DVI
4. HDMI
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | HP VF15 15 in.
Mini mac a1176 won't boot up (no signal being received by monitor)?
It will probably be easiest to replace it, but before you do go exploring to see if you can find an easy fix.
How to get inside:http://www.ifixit.com/Guide/Installing-Mac-mini-Model-A1176-Top-Housing/1103/1
Once inside, look around for anything that appears burnt or disconnected.
Look at these tutorials:http://www.ifixit.com/Device/Mac_Mini_Model_A1176
Make sure what you have looks similar to the pictures. If you can find what is broken, you can replace it using these tutorials also.
Apr 28, 2012 | Apple Mac mini Desktop Computer Desktop
Samsung syncmaster 275t won't start - what to do?
The Samsung monitor is okay, the problem is a compatability issue between the laptop and monitor. The VGA toDVI is the problem you are converting a analog signal to digital, the signal level degrades when that is attempted. If I understand this the laptop puts out the analog signal "VGA" and the monitor has the DVI input, "digital" The only other suggestion is turn off the laptop screen to see if the monitor will work.
Apr 04, 2012 | Samsung Syncmaster 275T Monitor
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
When computer is starting up monitor goes blank. I have to turn it off and back on
Sent in for warranty repair to Samsung. Appears there has been some problems with 932B & 932BW.
Nov 30, 2009 | Samsung SyncMaster 932B LCD Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Hooking up a Mac to tv
I ran into the same problem with my "50 maxent. The manual clearly states that mac resolutions are not supported. We won't let that stop us. Step one is to download switchresx. It's a simple utility that should allow you to define custom resolutions. http://www.madrau.com/ .
Step 2 is to download chicken of the VNC. http://www.macupdate.com/info.php/id/9517 . Once this is installed on a separate mac from the one you are trying to connect to the maxent take your mini and hook it up to the RGB port on the maxent and boot it up. Once this is done use chicken of the vnc to take control of of the mini with the other mac. Now you can change the resolution on the mini using switchresx which you installed on the mini earlier. In the case of the maxent you will need to set it to 1366x768 at 60 hz. If using another flat panel consult your user manual for the correct resolution. In my opinion there is no flat paned tv this should not work for.
Sep 30, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Sep 21, 2007 | Samsung SyncMaster 214T Monitor
Computers & Internet Logo
115 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
