Question about Sewing Machines
My euro pro stitch art machine ...can not get it to make stitches. threaded correctly, but needle won't even move up and down... what am i doing wrong
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
Contact supplier or manufactor
Posted on Dec 04, 2014
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
SOURCE: thread keeps snapping on NEW Euro Pro 32-Stitch sewing machine
I have the same machine with the same issues. I am so frustrated! Here is how I am going to solve my problem in 4 simple steps:
Step 1. Open garbage can.
Step 2. Throw piece of **** supposed sewing machine into can.
Step 3. Cover garbage can, cursing loudly.
Step 4. Purchase a brand name sewing machine with a real warranty!
Posted on Jul 04, 2011
Tally Girl
  • 1129 Answers
SOURCE: My Janome 204d Serger won't form a chain
I would suggest that you check the needles again, make sure they are both fully up into the needle housing. Also they should be at different heights in order to form the stitch sequence.
It is important that you thread the loopers first in the sequence shown in your manual, then the needles. So you may need to recheck the threading again and make sure the threads are in all the eyes correctly, especially the lower looper. Also some overlockers, have a sliding eye on the lower looper for ease of threading, if yours does, make sure it has been slid back to normal operating position.
When you have checked the threading up, take all four threads under the raised pressure foot and make sure that the upper looper thread and lower looper threads are not crossing over each other. Lower the pressure foot and try to chain off again.
I hope this helps you to resolve the issue.
Posted on Oct 11, 2011
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Oct 02, 2016 | Euro-Pro Sewing Machines
Euro-Pro sewing machine model9130H needle moves sideways and thread clogs up when starting to sew
Be sure to install a brand new needle.
If the needle bar is moving to the side when set on a straight-stitch, there is probably something loose or bent in the machine. Would recommend having it checked by a technician. Could also be the cause of the thread clumping or could be something else going on.
Apr 15, 2016 | Euro-Pro Sewing Machines
My euro pro EP382 problem: needle goes down & then it locks up. When I free it there is an extra thread with the bobbib thread that comes up. What can I do to fix this?
Euro Pro Sewing Machine - YouTube
? 0:59
https://www.youtube.com/watch?v=QndkRbDfM2w
Jan 20, 2009 - Uploaded by simplysoldstore
Euro Pro Sewing Machine. ... on piece on top then runs downthe right side of long and around the bottom up ...
EURO-PRO 380 INSTRUCTION MANUAL Pdf Download.
www.manualslib.com > ... > Euro-Pro Manuals > Sewing Machine > 380
Sewing Machine Euro-Pro Dressmaker 998B Owner's Manual ... take-up lever Palanca tensora de hilo Presser Foot Prensstela Needle plate ... Drop Feed Control / Control De Gota A. Push feed dog lever down to drop feed dog below needle plate for darning, embroidery and button sewing. .... This manual also for: Ep382 ...
Euro Pro Mechanical 30 Stitch Sewing Machine - Overstock ...
www.overstock.com > ... > Sewing Machines
Overstock.com
Rating: 4.4 - ‎5 votes - ‎$119.99 - ‎Out of stock
Shop for Euro Pro Mechanical 30 Stitch Sewing Machine. ... I can sew in the middle of the night and not worry about waking anyone up, it is so quiet, and it sews ...
Amazon.com: Distinctive Even Feed Walking Sewing ...
Jan 05, 2016 | Sewing Machines
My machine runs but will not pick up stitch or skips stitches. how do i fix or adjust my machine so it will sew.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Dec 02, 2012 | Sew Pro ZZ401 Sewing Machine
My sewing machine thread keep breaking i dont know if the needle is in right are if it is thread it is a euro pro denim machine
Usually there is a flat spot on the part of the needle that makes it so you can only install it the correct way. Try changing the thread. If it keeps breaking you will need to adjust the threads tension control. If it is too tight your machine won't be able to pull the correct amount of "slack" it needs to make a good stitch. You might only need to turn the adjustment a small amount to make a big difference. The thread should come off the spool and go through an arm that moves up and down. Then the thread loops around the tension adjustment. It will most likely be a knob or dial with numbers on its face. I hope this helps.
Nov 03, 2011 | Sewing Machines
The needle is threaded top and bottom but when I run the machine to sew the thread isn't sewing on to the fabric..I'm not sure but I think the thread around the check spring holder is midway or rather not...
Recheck the threading on the top side. When you pull the thread at the needle is there tension on it? If there is no resistance than there's no tension. If it breaks it is either not threaded correctly or the tension is way too tight.
If that is correct and the the thread on the bottom has a little bit of tension when you pull on it, it should stitch --- However not stitching at all can be from having the wrong needle, wrong brand, type, or in incorrectly. Sometimes even the wrong size can prevent stitching, like when youre sewing through heavy/thick material and using too small a needle.
Check out those three things and then see if it won't sew correctly for you.
Apr 21, 2011 | Euro-Pro 801B Sewing Machine
When sewing, thread knots under fabric sometimes. Other times the stitching is missing.
Hello:
When you have stitch problems try to remember TNT or TTN.
1. Raise your pressure foot and re-thread your top thread. (Thread)
2. Replace your needle or at least check it for being bent. (Needle)
3. Adjust your top tension. (Tension) Get it? TNT.
4. Make sure your bobbin is in correctly. If it is upside down or had the thread unspooling off the correct side.
5. Make sure your needle and your thread are appropriate for your fabric application.
Good luck.
Mar 13, 2011 | Euro-Pro Sewing Machines
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
Bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Dec 03, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
