How do I clear pictures from meet 24 - Office Equipment & Supplies
Can you take bottles of alcohol in your carry on luggage or checked luggage
Carry on is OK, but must meet the TSA standards, same as all other carry on liquids. 3 ounces or less.
Checked is also OK, no limits, but pack securely to avoid breakage and pilfering by baggage handlers.
Mar 15, 2015 | Luggage & Travel
When I turn on camera to take picture, it says memory full. How do I clear this?
tego34:
From the user manual for this camera (click here) page 247, it says "Memory is full. If you want to record more files, delete files that you no longer need" and references page 161 in the same manual.
On page 161, it gives you the directions for deleting un-needed files (pictures).
I would suggest transferring all of your pictures to a computer using Picasa and deleting the pictures that you've taken from the camera.
If you're using the memory that is built-in to the camera, it is much too small to hold many pictures. You should buy a 2GB SD card that meets the specifications in the user manual page 180.
Feb 17, 2011 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My canon xsi will not focus at all on auto focus. any ideas?
Try cleaning the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol.
May 31, 2010 | Canon EOS Rebel XSi Digital Camera
When tv is turned on it takes 35 minutes for the pitcure to come on, like it is warming up. It is a flat screen digital tv and only 3 years old.
u have to replace apart inside the tv (picture tube base)
which connects picture tube to circuit board,,, call aservice pro...the symptoms are blurry picture & after some time picture gets clear
Apr 02, 2010 | Bush 5693D 24" TV
Nikon D300, purchased 14 months ago. Pictures are not as clear.
Try cleaning the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Jan 03, 2010 | Nikon D80 Digital Camera with 18-135mm...
Less than 24 months old. Power up, has 3
sorry to say but your LCD panel is failing, and will have to be replaced sonys panels are expensive
Dec 05, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
LOcation of workstaion 24
I can tell you that does not meet space requirements for ventilation, service room or safety.
As far as your health, with the filtration and safety requierments involved with those machines, you are fine.
But any smart service rep will refuse to work on it, and they do not have to in that type of location.
that type of location will cause operational problems. I can guarantee a location like that does not meet ventilation requirements.
Feb 20, 2009 | Xerox WorkCentre M-24 Color Copier
Dirt devil ultra vision turbo - how to change filter
remove the dirt cup, the top part should turn a little bit and then separate ( look were the clear plastic meets the colored top you might see a little picture of a lock and a open lock turn the lid towards the unlocked position , the filter should be in there
Sep 17, 2008 | Dirt Devil Vacuums
Sharp AL 1644
here is the fix: Press "C", press the exposure button (below the picture of the little man), press "C", press the exposure button. When you do this all the indicator lights will turn off. Now input "24", press the green start button, input 07, and press the start button again. Now turn the copier off and back on with the power switch on the side.
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "24", "Start Key", "7", "Start Key"
Sep 09, 2008 | Sharp AR-5316 Advanced Digital Imager...
81 people viewed this question
jasbo
jasbo
