Question about KitchenAid Ovens
How do I remove the door of my Kitchenaid built in oven YKEBS107DW3 installed in 2000
    Director Badge:
    Uploaded 100 video answers.
  • KitchenAid Master
  • 488 Answers
Watch this! Shows how to disassemble door on most of Kitchenaids and Whirlpools HOW TO REPLACE DOOR HINGES ON KITCHENAID WHIRLPOOL OVEN
Posted on Jan 24, 2015
the dr
  • 447 Answers
SOURCE: KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Posted on Jan 02, 2008
  • 3422 Answers
SOURCE: replacing inner door glass kitchenaid kebc208ss
Click HERE for the service manual and refer page no. 21-22
This will solve your problem.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 16, 2008
  • 311 Answers
SOURCE: No power and door locked after starting self cleaning cycle
Thermal fuse went out by door latch and thermal fuse on back of oven probably tripped too; once failed they need to be replaced. This is probably a job for the repairman as something caused fuse to go out in the first place; unless resolved it will recur. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
ginko
  • 19396 Answers
SOURCE: how do I remove the oven door of Frigidaire Model
Hi.
You have to open the door all the way through.
Then remove the two locks from the hinges.Pull the tabs out, help yourself with a screwdriver.
Grab the door firmly on both sides, pull up the top of the door and slide it out.
Here all diagrams and parts for your appliance.
Regards.
Posted on Mar 04, 2010
How to remove oven door
hi deirde.
try this or go to the link at the bottom.
To replace oven door(s):
  1. Grasp door at each side.
  2. Align slots in the door with the hinge arms on the range.
  3. Slide the door down onto the hinge arms until the door is completely seated on the hinges.
  4. Push down on the top corners of the door to completely seat door on hinges.
How to remove and replace the oven door - KitchenAid Product Help
producthelp.kitchenaid.com/...Ovens.../Oven.../How_to_remove_and_replace_the_oven...
How to remove oven door Google Search
Nov 03, 2017 | Ovens
Replacing inner door glass kitchenaid kebc208ss
Goodluck,
Feb 16, 2008 | KitchenAid Architect Series KEBC208KSS...
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
Sep 15, 2009 | KitchenAid KEBC107 Electric Single Oven
KitchenAid Built-in microwave middle glass shattered
not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204456573.pdf
then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186032.pdf
the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kemc308kss&siteCd=WHRCOM
Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
Dec 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Dirty oven window
Try to remove the door. For the Kitchenaid, thereis a hinge on each side with a latch that flips up. Once the door is removed, remove all screws and you should be able to get at glass. Be very careful, the Kitchenaid had four panes of glass.
Jan 08, 2008 | Whirlpool GBD307PRS Stainless Steel...
Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
Jun 02, 2007 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
105 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
