Which chip off the motherboard hold customer information and is used to disconnect services and how can it be bypassed
  • Computers & ... Master
  • 3,368 Answers
Yes, that should be answerable but first read the instructions they contain some amazing information. we can not help you because we have no idea of what you have.
Posted on Dec 04, 2014
Clear cmos how to;'?
What type of computer and motherboard ?????
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Power down the system and disconnect the power cord.
Wear an anti-static wrist strap to avoid electrostatic discharge damage to the Asus motherboard or CMOS chip or other sensitive components.
Remove the cover and locate the CMOS coin cell battery and remove it from the system by gently pushing on the retaining clip and popping the battery out although on some motherboards cmos batteries are soldered in
Discharge the CMOS chip by leaving the battery out of the system for up to an hour, depending upon the particular chip and motherboard combination.
Replace the battery and replace the cover on the system. Connect the power cord and boot the computer.
Save changes if prompted by the BIOS for system memory, drives detected, and other settings, and set the date and time if prompted at this time, or alternately set the date and time when the operating system finishes loading.
If your computer does not have a CMOS battery or you're unable to find it you'll need to do a hard reset on the CMOS using a jumper or dip switch on the motherboard.Information on finding these can be found through your computer or motherboard documentation.
or you might set failsafe or optimised defaults
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaultsor load optimized defaults press escape then press f10 to save to cmos to restart
Dec 03, 2013 | Computers & Internet
Want to unsubscribe on EBay
Sometimes you have to bypass the "customer service" mess and go directly to corporate to get resolution.
Nov 21, 2013 | Iwill P4ES Motherboard
Toshiba 32bl505b tv menu locked
Disconnect the AC power for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of the unit.
Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will appear. Enter your new password.
The V-Chip is bypassed by holding the zero key on the original remote hand unit, and at the sane time holding down the volume down on the front of the TV set. This should reset the oide so you can enter a new one.
Jan 15, 2013 | Televison & Video
How to clear cmos data
If your computer does not have a CMOS battery or you're unable to find it you'll need to do a hard reset on the CMOS using a jumper or dip switch on the motherboard. Information on finding these can be found through your computer or motherboard documentation.
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Aug 18, 2012 | Computers & Internet
Acer laptop was given to me needs password bypass, can not find BIOS battery or link
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 13, 2011 | Computers & Internet
I have one red ring on my xbox360 elite its on the 4rth controller port how do i fix it please tell me
Try the following resolutions in the order in which they are listed:
  1. Turn off your Xbox 360 console, disconnect and reconnect all cables, and then again turn on your console. If this step doesn't resolve the problem, try step 2.
  2. Turn off the console, and then disconnect any connected accessories, such as controllers, Xbox 360 Memory Units, and the Xbox 360 Hard Disk. With these accessories removed, restart the console to see whether the problem persists and to pinpoint whether the problem involves the console or an accessory. If this step doesn't resolve the problem, try step 3.
  3. If you continue to experience the problem, contact Xbox Customer Service.
    If the Xbox Customer Service agent cannot help you resolve the problem, you may have to return your Xbox 360 console to Microsoft for repair. For more information about how to contact Xbox Customer Support or to request repair of your Xbox 360 console, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
Aug 27, 2009 | Microsoft Xbox 360 Console
L.e.d reads starting dissabled do to thief system
THE KEY HAS A CHIP INSIDE IT TO PREVENT THEFT. IF THIS KEY HAS THE WRONG RESISTANCE VALUE THEN IT WILL NEVER START. IF THE KEY IS A DUPLICATE, THEN YOU MAY NEED TO GO TO THE DEALER WITH PROOF OF OWNERSHIP AND THEY WILL BE ABLE TO MAKE A NEW KEY. I COULD BYPASS THE MODULE BUT SOME SECRETS ARE ONLY FOR THE PROS. IT WOULD BE A BREACH OF SAFETY AND SECURITY TO INFORM YOU OF THE BYPASS SEQUENCE. I WOULD ASK MY CUSTOMER FOR PROOF OF OWNERSHIP BEFORE ATTEMPTING THIS PROCEDURE. SORRY, BUT I AM SURE THAT THIS ANSWER DOESN'T HELP MUCH. BEST OF LUCK TO YOU. THANK YOU FOR AN HONEST RATING AND FOR USING FIX-YA.
May 11, 2009 | Cadillac Seville Cars & Trucks
Resetting the v-chip password so i can remove it and watch all that i want
I had the same problem. Here's what Toshiba emailed to me:
  1. Disconnect the AC power for at least one minute to reset the clock.
  2. Adjust the volume to the minimum using the Volume down button on the front of the unit.
  3. Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
  4. The user menu will appear with the V-Chip cursor blinking.
  5. Press the ENTER key on the remote control and the NEW PASSWORD menu will appear.
  6. Enter your new password.
Hope that helps!!
Sep 13, 2008 | Toshiba MW20FM1 20 in. Combo
Presario v3000
one way is bypassing. which can be done at chip level servicing only.
else there is a option like we can use any tool like ERD.. but we cant assure that u will get solved by that method.
only sure shot method is chip level servicing.
so u should take it to company(if with in warranty) else take it to some local service centers.
May 16, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
