Question about ViewSonic PJD6531W Projector
How to reset Username & Password for a ViewSonic PJD6531w projector? I can connect via LAN to web server which prompts for a (unknown) login. Thanks Ken
Basic problem is blue LED illuminates but no projector lamp!
BingoDabbers
  • 102 Answers
SOURCE: viewsonic pj 800 projector
Yes.
Posted on Oct 06, 2007
Marrie
  • 563 Answers
SOURCE: Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Posted on Mar 26, 2008
  • 6 Answers
SOURCE: Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
Posted on Aug 19, 2009
mastertech48
  • 149 Answers
SOURCE: viewsonic pj551 projector lamp will not light
Without more info, I'll tell you some things to check...Make sure the power cord is still plugged in firmly. With the unit unplugged, check the lamp for damage, looseness, etc. Was the unit hot when you moved it? If it was, the lamp was more prone to damage due to the heat. Always be VERY gentle if you have to move a hot projector for any reason. Did the unit sustain any hard impact while moving? Impacts crack boards, loosen connectors, and damage lamps. Make sure the lamp door is closed completely--there is a switch on the door to prevent the projector from coming on if the door is open. Make sure you didn't press any buttons on the unit too hard while holding it during moving.
Posted on Sep 09, 2009
  • 6 Answers
SOURCE: Viewsonic PJ550 lamp
Problem 1) The projector should put out a burst of 7000-15000 volts to start the lamp, and then immediately drop down to 60-100 vlts to keep the lamp lit. It sounds like the bulb blowing took out your ballast, or the ballast going out took the bulb (uncontrolled current = overheated bulb = boom)
Problem 2) Thats not a problem at all. HID lighting uses an arc to create light, just like welding creates light. Since it uses an arc, and not the heating of metal, there is no filament to test the resistance of. All the bulb is, is a special mixture of gasses and two very durable electrodes, with a gap in between.
Posted on Dec 02, 2009
Viewsonic Pjd6531w bulb not turning on and projector requires unplugging to turn off
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 23, 2014 | ViewSonic PJD6531W Projector
Viewsonic pjd6531w projector flickers
Look to the color wheel for your problem. They do wear out.
Dec 13, 2013 | ViewSonic PJD6531W Projector
I have a netgear range max, it has been working fine. Just last night nothing wireless in my house works. Cable modem works. Power light on netgear box is green. "i" icon is flashing green,...
You need to reset and reconfigure router
please follow the steps to reconfigure router
RESET THE ROUTER:
1. Make sure router is connected to power supply and is on while you perform the task below. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing. Turn off the router and turn it back on after a couple of minutes.
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Regards,
Prakash
Apr 08, 2011 | NetGear WGT624 Wireless Router
I cannot access the web via wireless. Appears that something is blocking or missing on the home network connection settings. Wireless is showing good connection to network. Getting IP from router. How...
It cannot be the firewall, since your Lan connections work.....
Check the wireless settings on the router, check the SSID and the Security key.
If this is happening with one wireless computer, Check that the wireless adapter is turned on and drivers are installed correctly. Uninstall and re-install the drivers.
You can try resetting the router and reconfiguring the wireless settings .
Router reset:
This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 23, 2010 | Linksys Wireless-G WRT54G Router
I am trying to connect netgear router to my modern ATT can you help me out?
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
16. Click Apply.
Jun 08, 2010 | NetGear WGT624 Wireless Router
Netgear wireless-N 300 router directions
Direction for using and configure router
16. Click Apply.
Hope it can resolved your query
Thanks for using Fixya
May 05, 2010 | NetGear WNR2000 Wireless Router
NETGEAR wirless router installation
You can use below steps to install router
ROUTER SETUP
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.1.1 address bar. press enter
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on lan ip setup under advanced.
6. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
7. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
8. Power off the dsl modem and the router after making the connections.
9. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
10. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
11. Access the router (http://192.168.10.1).
12. Login to the router (Username = admin Password = Password).
13. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
14. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
15. Click Apply.
16. Logout of the router.
17. Open up another browser window and try to access internet.
Please rate the service positively if issue resolved
Apr 04, 2010 | NetGear RangeMax WPN824 Wireless Router...
TalkTalk Modem Smartax MT882 to Netgear RP614 problem
Well your modem and router IP is same thats why you can't connect your router with modem
your have changed IP of the router,please follow steps to resolved your issue
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 address bar. press enter
16. Click Apply.
Hope it can resolved your issue
Happy to help
Apr 04, 2010 | NetGear RP614 54 Mbps 4-Port Web Safe...
Pc has been wiped now i want to reconnect to wireless router
Hi
please follow steps to reconnect to wireless router
16. Click Apply.
please rate service positively
Mar 26, 2010 | NetGear WGR614 Wireless Router
KyoceraMita KM-4050: System Board reset for authentication
Login with 5050 as the username and password via the web browser and turn off authentication.
Nov 27, 2009 | Office Equipment & Supplies
ViewSonic PJD6531W Projector Logo
Top ViewSonic Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
