I have a TCL 21inch CRT TV. When it plug to AC some noise come form the SMPS transformer (chopper) did not TV work. Please can you guess the problem.
I checked AC cord, Fuse, Rectifiers, Capacitors, Resistors etc. in the power supply stage. Everything is OK. I replaced SMPS control IC (TEA1506P) and Transistor (K2645).
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
Sounds like SMPS transformer is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 05, 2014
Slinteriors
  • 8617 Answers
SOURCE: TV HV
usually when thiers arching its usually inside the flyback connection that causes the arching.I reccomend changing the flyback.
Posted on Apr 13, 2008
  • 4234 Answers
SOURCE: Sanyo ST-21G1 dead set
There should be a small valued cap in the primary side (22ufd?) at 250V. Check that. Also, look for other small caps int he range of 2.2ufd with 200V ratings in the same general area.
Dan
Posted on May 07, 2008
Maciso
  • 125 Answers
SOURCE: LG CRT HDTV Dead no picture
if you have the b + acording the manual then you loose it
could be many things like the vert. circuit, the crt itself or
the flyback,
Posted on Aug 06, 2008
SOURCE: LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
Posted on Nov 25, 2008
  • 4234 Answers
SOURCE: sony color TV model kv-c29 11d blown power supply ic and transist
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
Thanks,
Dan
Posted on Jan 21, 2009
Noisy flyback transformer tcl CRT TV model 14F1
They often begin buzzing when the oil inside them gets old or evaporates from a cracked housing. It needs replacing however be very careful. Flyback have 50000 to 100000 volts in them even when the tv is off. There is a safety discharge procedure however if you are not familiar with replacing a flyback do not attempt it yourself. FLYBACK TRANSFORMERS CAN SEVERLY INJURE OR KILL YOU.
Jul 17, 2016 | Televison & Video
After 3 to 4 min. the TV shuts itself off. It seems like it is tripping the AC connection.
If it happens after some time it is usually a overheating problem.
Jul 29, 2008 | Televison & Video
Tcl service mode
Press & Hold Vol-ve and CH+ button together, then re-plug the TV to AC mains wall socket, with its ON/Off switch at ON state. This must make the TV to service mode. google.com/+GopakumarGopalan
Nov 18, 2013 | Televison & Video
High pitch noise after moving?
Might be come out from SMPS transformer or LOT. Core vibration. Check it.
Sep 11, 2013 | RCA F36648 36" TV
SONY MODEL KV-G14Q2S TV IS ALWAYS ON STAND BY INDICATOR AND REMOTE SENSOR INDICATOR LAMPS AND TIC-TIC SOUND GENERATES FROM CHOPPER TRANSFORMER
The SMPS sounds as if it is OK. The line output transistor has probably failed and maybe the transformer. Before leaving it as repaired, check the tuning capacitor across it and check the 135volt HT line for stability.
Hope that helps.
Feb 16, 2011 | Sony Televison & Video
MY RCA 27" WILL NOT TURN ON, HAVE POWER TO THE FUSE, THE FUSE IS GOOD ALSO BUT THE DEGAUSS RELAY DOES NOT CLICK AND NO OTHER CLICKS ARE HEARD EITHER, WHAT COULD BE WRONG?
you need to check the voltage output of your power supply section.This power supply supply is a switching type power supply.there is a chopper transformer in there.its supply is a dc voltage unlike any other transformer which is AC supplied on the primary..First step.
1.Using a multitester measure the primary supply it is a DC voltage around 220v - 110 VDC
2.Measure the secondary output.The out put is AC voltage the supply for the B+ going to plyback is 115vdc the second output is 12v run through a regulator and the regulator lower the voltage to 5vdc.this 5vdc supplies the system IC and the jungle IC.this ic process the switching of the plyback transformer and the plyback transformers output supplies the voltage of the whole system including your relay in the degaussing section....once the plyback is activated the tv will now turn on...
good luck!Hope i helped you..
please rate my help..god bless!
Jun 13, 2010 | RCA F27641BC 27" TV
Akai 25'' TV no power from SMPS. voltage available up to filter capacitor. No smps output. smps power transistor ok. Please responce nagarajak60@yahoo.com
try to check its high voltage section for axed HOT or flyback. Also check its regulator. Maybe start up resistor or check the chopper circuit. You should at least have an standby voltage on the secondary side.
Oct 28, 2009 | Televison & Video
High pitch sound coming from circuit board, cannot
First, you will want to isolate the problem. Is it feedback from an AC outlet you have it plugged into? Is it a recent noise that just started with no changes to Tv or its environment, then you may want to consider that a circuit is going and decide if it is worth repairing, You should find that type of fix at a shop for under $100
Sep 27, 2009 | RCA F35317 35" TV
No pic
When it makes a buzzing noise turn it of well unplug everything and plug back in after 30 secounds it should work if not it will not go away for 1 to2 months. Hope it works
Oct 24, 2007 | Televison & Video
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
