Question about Radio Communications
I have a red fox edge I used it for 2 days it stopped working wont power on can't charge it
Tried to charge it it won't in there are no indicator lights working anymore
  • 3,368 Answers
It sounds like you over discharged the battery and destroyed it. Very few batteries tolerate excessive discharging.
Posted on Dec 04, 2014
My ipod won t charge
It could be 1 of 2 things. The first 1 I have had the experience of accidentally leavng my iPod plugged in charging for over a day. What happened...it killed the ability of the iPod to hold a charge & yes I tried with another battery & it was a no go. The second issue could be that your actual power supply cable has gone bad and won't work anymore. Now you didn't specify on which manner you're trying to charge it so if I didn't address your issue my apologies. There is a 3rd thing and no its not a combination of the 1st 2 I mentioned happening in conjuction...The 3rd thing could be that the power outlet you're trying to use doesn't work anymore so try another outlet plug.
Oct 23, 2013 | Audio Players & Recorders
Iphone won't charge unless it is completely powered off
Luckily, there are some tracks you can try to fix it.
iPhone wont charge when turn on
# Check Charging Accessories
# Clean Charging Port
# Hard Reset Your iPhone
# Using iPhone Recovery Mode
# Restore iPhone to Factory Settings
http://www.recoveryiphone.net/article/fix-iphone-wont-charge-when-turn-on.html
try practical methods to fix your problem, and if it still can't get your problem solved, just take it in for service at the nearest Apple Store in your area to get the help of the Apple employee.
Mar 20, 2013 | Apple Iphone 4s latest Model - 32gb -...
Battery won't hold charge
It most likely needs a new battery, but you could try giving the battery a full charge first:
1. Power off the laptop and disconnect the power adapter.
2. Re-seat the battery (remove/reinsert)
3. Reconnect the power adapter and let it charge overnight. (6 hr+)
4. Disconnect the power adapter.
5. Power on the laptop (run under battery power only)
If it doesn't boot up and shuts down immediately, it's probably time to see about a replacement battery.
2.
Jan 11, 2013 | Samsung Q430 Laptop
2001 ford taurus power draining new battery & new alternater won't work when cables are removed from battery
That suggests that the problem is in the harness, something in the connector or wiring is causing an open circuit. You will need to have the circuit tested to find the fault. Ford alternators have known connector issues & new aftermarket connectors are readily available at most auto parts stores.
Oct 25, 2017 | 2001 Ford Taurus
Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 03, 2012 | Black & Decker Black and Decker 18V...
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
My powerbass 150 amp was running perfectly one day, shut it off by the rockerswitch on the back to go to bed. Got up next morning, turned it on by the rockerswitch and no sound anymore, after about 5...
The problem with amps is they generate lots of heat when they are working and semi-conductors don't like heat, so overtime they fail. In your case either somekind of protection circuit has stopped an overload or one of the main semi-conductors that does the work has failed. It's off to the repair shop with it!
Aug 19, 2011 | Audio Players & Recorders
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
Radio Communications Logo
76 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
