Question about Refrigerators
My you tube is not working and doesn't come in at all what should I do
  • Refrigerators Master
  • 3,368 Answers
What type of refigrator displays you tube?
Posted on Dec 04, 2014
Ice maker doesn't work
remove im and look into fill tube,if there is ice in fill tube,defrost with hair dryer and replace selinoid valve at bottom back side of unit.if not frozen replace im
Apr 09, 2013 | Kenmore Refrigerators
I have a Kenmore gas range. The bake option doesn't work but everything else does. I've replaced the ignitor and still doesn't work. Any suggestions?
does the ignitor glow orange?if so could have a bad gas valve,clogged orifice,gas can't enter the tube.if it doesn't glow,bad clock assy.next time send the model number off of the machine
Nov 21, 2012 | Kitchen Ranges
My simpson dishwasher doesn't work anymore
Click on link or copy and paste in your browser: http://www.manualowl.com
Apr 13, 2012 | Washing Machines
Sound doesn't work on you tube videos
The video is you made for YouTube? and the sound doesn't work on YouTube?
Well, you should check the Video Format for Uploading to YouTube first:
http://www.ifunia.com/youtube-column/best-youtube-video-format.html
And there are some other tips on YouTube videos uploading and downloading in iFunia YouTube column, you could turn and go to it.
Dec 29, 2011 | YouTube Computers & Internet
Switch either sticks or doesn't work. Fluid is evident in the clear tube. How do I get rid of fluids from the tube?
First of all, there shouldn't be any fluid in the tube. This switch works on air pressure that is generated when you push on the sink button. The tubing that came with this is black, did you change the tubing ? If the tubing that is on there has a hole in it or isn't fastened correctly, it wont work properly. Secondly, check your plugs. The insinkerator plug should be in the outlet and your disposal should be pluged into it.
To remove the tube, it just pulls off both ends that its connected to. They are just push on fittings and do not actually have a nut or something to connect it. Get the fluid out of the tube and reinstall.
Jun 05, 2011 | Emerson InSinkErator STS-S0 Sink Top...
The washer will not stop filling up with water and spilling water on the floor unless manually stoped. Sometimes it spins and rings the clothes out and sometimes it doesn't . With either problem it...
Remove front of machine with putty knife/slide knife in at top of front on left and right u will see the tabs.. there is a pressure tube that attachs to tub on the left side remove tube. DONT BREAK OF THE *** it is most likly pluged use small wire to clean tube and the little *** that it gos on to// put tube back on (SPIN AND DRAIN MACHINE) test on all load sizes.. good luck thank you for voting.............................
May 21, 2011 | GE Washing Machines
Doesn't work/open you tube website
If you want to open youtube website, connect to the net and type www.youtube.com in the address bar to open the website.
Kindly rate my help+ Thank you
May 10, 2010 | YouTube Videos
Need convergence tubes price and where to order
Hi, set doesn`t have "convergence tubes", it has 3 picture tubes and it has 2 convergence IC`s post the symptom you see on the screen or tell us where you got the term "convergence tubes". If it needs all 3 tubes the set is not cost effective to repair as they are veeery expensive to buy and you WILL need an experienced tech to install them and then align them, convergence repair here in central florida runs about 275.00, price for your area may differ greatly, send us more info if this doesn`t help, video-tek
Jul 01, 2009 | Sony KP-57WS500 57" Rear Projection...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
