Question about Husqvarna Garden
I have a Husqvarna 2554 lawn mower that is suppose to go 5.5 mph but only goes 3mph
The shifter that go forward has a lot of slack in it has been like this since I bought it new
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 165 Answers
Probably need to have someone adjust the linkage / cable for the shifter. Sounds like it may not be going into the highest gear available.
Posted on Dec 04, 2014
I change my belt on my husqvarna awd mower, and it is pulling very slow,the belt is on and the cable is fine,there is a lot of slack in gage when i pull it to mower.
you routed the belt according to the diagram? did you get the right part number for your belt? if your mower is AWD it's under warranty, they just came out not long ago.
Feb 08, 2015 | Husqvarna Garden
Husqvarna riding lawn mower (YTH21K46), mower blade clutch cable routing.
Its pretty straight forward to fit the cable, if it is not pulling the jockey hard enough into the belt it is more likly the belt is incorrectly fitted or has stretched.
Jun 02, 2012 | Husqvarna Garden
Reverse has got real slow, forward is slowing down to.
yea i know i did the trick i bought 2554 huq i have a lever shift i cut the platic on the reverse tp make it longer and it go much faster. now for floor pedal need make a bracket higher on pedal should make go down further and faster too.
Jul 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna CT151 Smoking
the belt is smoking because a pulley isnt spinning like its supposed to. its gonna break the new belt if you don't remedy the problem. try taking the belt Back off. then see if you can spin the pulleys by hand with no belt .
Jul 31, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Lawn mower was working fine now it will go into
  • check the belt - it could have broken or come off the pulley
  • tension spring may have broken or come off
  • after that - it could be any linkage from the shifter lever to the lever on the transmission
  • worse case your hydrostatic transmission failed, which is unlikely
if you need any parts or further information, please call John at 860.233.5439 x222
www.ButlerPower.com
Apr 17, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Placing the belt on LGT2654
Does anyone have a layout on how the belt goes on the 2554
Jul 14, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a 2005 husqvarna lawn tractor. 24 hp, 48 in deck, the transmission runs fine on level ground but when i go to an incline the tranny slips and i hear a clunking sound, and if i travel farther up hill...
sorry. I don't have an ansewer for you however I might have some helpful hints. Your mower should be going dam near 5 MPH. But yes can't cut in reverse. you have a belt going from the trans axle to the motor. It could be slapping against the frame. The idler puller or the tension pulley could be wobaly where the bearings are gone out. If you remove the 4 bolts on the back of the mower under the seat and gas tank it should visable tell you the story. My question is mine hits gears real hard as if trans mission needs oil or internal damage.
May 09, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
96 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
