My Siemens washing machine displays ES or E5 code and stops after 10 minutes. Tell me the solution
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
MAY BE A SUDS SENSING PROBLEM
Posted on Dec 05, 2014
  • 249 Answers
SOURCE: Indesit Evolution 1600 WE 165 washing machine has stopped
its more the likely the water heater
Posted on Dec 09, 2007
  • 185 Answers
SOURCE: getting error code e:02 on
model number please
Posted on Mar 28, 2008
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
Posted on Aug 22, 2010
SOURCE: i have washing machine hotpoint
mine has just donethe same today have you had the solution yet please
Posted on Nov 23, 2010
  • 6277 Answers
SOURCE: fault code comes up s5
Sorry but you do not say what make and model it is- front or top loader?
This possible cure applies to both!
Check the (drain motor) lint tray/filter if you have not done so already, especially as you say that it doesn't pump out the water. Either the filter is blocked OR the drain motor is malfunctioning. In either case that is enough to stop the machine.The filter is normally situated behind the front lower panel, certainly in most front loaders.
Before turning the filter holder anticlockwise to remove have a water receptacle and/or rags available to catch any water. It is a good habit to check the filter regularly!
It is also a good habit, especially in areas of 'hard' water to run the contents of a sachet of proprietary anticalc powder through regularly. It will help to keep the heating element clean AND the filter to a certain extent.
Hope this solves your problem,
John C
Posted on Feb 09, 2011
Siemens washing machine display F21 flashing. Fault is not resetting after power off.vario perfect iq 300.
Try this, unplug it and press and hold down the power button for 10 seconds and then plug it back in and see if the error code has cleared.
Aug 28, 2016 | Siemens Washing Machines
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
Siemens washing machine displays error f-02
the heating element has failed
perhaps a temp sensor HTC
etc
or the element has gone open circuit
this is caused because the machine did not get too the preset temp ...
Sep 06, 2014 | Siemens Washing Machines
F26 washing machine Siemens s1272
The F26 error code on the Duet washer is a door switch error.
Disconnect the unit for 10 minutes and plug back in to power.
Check the display for any kind of power indication.
If you have any leds of power indication, try adjusting the door switch.
May 07, 2014 | Washing Machines
How to unlock siemens wd12d520/01
unplugging the appliance for 10-15 minutes should automatically release the door unless the appliance is still full of water. If it is then this needs to be drained out manually by lowering the waste hose into a bucket until the water level is below the door seal
Apr 11, 2014 | Siemens Washing Machines
Error E5 on Balay ts7210 washing machine
This is a door lock problem can be door lock or main PCB
Dec 20, 2013 | Washing Machines
Siemens stops without going into the spin cycle
when it stops is there and f:XX error code on the display? were XX is a number.
Jul 18, 2009 | Siemens WM14S794GB Front Load Washer
Error code E5-5
I didn't use mine for several years then just started again. It stopped after 15 minutes so I read the manual and used a silcone lubricant on/under the treads as recommended. That definitely helped and it was working again quite well for about a week or two. Now I get the error 5 again. Wondering if I needed to add MORE lubricant the first time so I am going to do it again tonight. Maybe it is the roller pully that needs the lubricant. Who knows. I just want it to work!! I am determined. :)
-becky
Feb 08, 2009 | Bowflex TC3000 Treadclimber
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
